Lenovo flex 5-14alc05
    Originally posted by mrcliem View Post
    Please Help.. I have the same problem with 14ALC05, the ESC and Caps lock led On and the power led blinking...
    I have tried all the bios posted here... unfortunately none of the them did not work.
    I attached here the dump of my corrupt Bios... Would you please help me take a look at it... and please help me point which bios that may work..
    Thank you.. Appreciate all the help
    NEED snid
      Originally posted by shiyab View Post
      NEED snid
      Board Number:
      LC56-14A SVT 203021-1 448.0MD08.0011
      SN : PW013T89
      MTM : 82HU00JBID
      MO : PWN0B2204006
        Board Number:
        SN : PW013T89
        MTM : 82HU00JBID
        MO : PWN0B2204006
        HI TRY NEW file
          HI TRY NEW file
          unfortunately its not working... still give the same condition as before... power led blinking, caps lock and esc light ON
          Thank you fo your help...
            bord issu
            amd chek cpu
              bord issu
              amd chek cpu
              Correct.... CPU need reballing...
              After redo thermal paste and tightening the cpu cooler, it boots up even with original BIOS
              shiyab Thank you so much for your help
                Common problems amd no disp
                  good
                    Originally posted by SMDFlea View Post
                    Re: Lenovo flex5 14alc05
                    try. Flex 5-14ALC05 Laptop (ideapad) - Type 82HU
                    tested working
                      Hi , i have this model with sn: Pw004f7x
                      can you help me with correct bin file?
                      thank .francesco
                      stop posting pictures!!...
                        thank .francesco
                        post the S/N, post the original content of the bios chip, the motherboard model, the full name and model of the laptop,type,etc.
                          Ok
                          I don't have a BIOS reader ,
                          After Windows update laptop start on black screen
                          I tried USB fat32 Stick with file .cap from Lenovo site' and fn+r . USB start read but nithing change
                          Ideaflex 5 14alc05
                          Sn PW004F7X MTM:82HU00GEGE
                          MO:PWN0B1B11017
                          F4302 10a\32
                          Thanks you
                            Ok
                            Ideaflex 5 14alc05
                            MO:PWN0B1B11017
                            F4302 10a\32
                            Thanks you
                            you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
                              Ah ok . I Hope in a solution without reprogram the chip Thank you
                              Merry xmas
                                Hi, i've have found a CH431a programmer and i read the corrupted content .(saved like bios dump.zip)
                                Ideaflex 5 14alc05
                                MO:PWN0B1B11017
                                F4302 10a\32
                                you can solve the failded bios? thanks
                                  Ideaflex 5 14alc05
                                  MO:PWN0B1B11017
                                  F4302 10a\32
                                  File is corrupted or wrong chip.
                                  Become a Badcaps supporter
                                  Thanks to all supporters.
                                    Thanks . I use asprogrammer software.
                                    Chip soldered on motherboard connected with cable adapter ed recognized by software .
                                    I can retry to read with ch431a software
                                    You know a video tutorial using ch431a with cable ?
                                    Thank
                                      HI,
                                      i upload 2 dump file read with CH431A software
                                      on bios chip was write
                                      74M12JWSI0
                                      2132
                                      asprogrammer software autodect it as W25Q128FW 1.8V.
                                      if dump didn't work , is there another way to resolve?
                                      thank you
                                        HI,
                                        74M12JWSI0
                                        2132
                                        thank you
                                        bios
                                          hi, thank you for the file .
                                          Using CH431a SOFTWARE i erase and blank the chip , open you bin file and write it on chip but nothing change.
                                          i retried with asprogrammer software and bios work .. no i test it and give you feedback.
                                          Thankyou very very much.
