Please help unlock 845 g8
    Originally posted by rex98 View Post
    after reseting bios to defaults just flash the original bios and the password will be cleared
    Thank you Boss !!! Everything working like a charm.
      hi i have 845 g8
      in end point security error kindly fix my bios
      Serial Number : 5CG1490GH4
        Originally posted by Muhammad Faizan View Post
        hi i have 845 g8
        try
        after flash bios
        reset default
        and re-flash original bios
        enjoy
          Intente desbloquear el bios , pero no puede y ahora no me enciende el equipo podria alguien ayudarme a sacar el main y ec del backup para intentar reprogramar nuevamente agrezco infinitamente
          Mod 845-g8
          sn/ 5CG149410C
          I tried to unlock the bios, but it can't and now the computer won't turn on. Could someone help me remove the main and ec from the backup to try to reprogram again, I thank you infinitely
          Mod 845-g8
          sn/ 5CG149410C
            Mod 845-g8
            sn/ 5CG149410C
            Mod 845-g8
            sn/ 5CG149410C
            Alguien podria ayudarme?
            Somebody could help me?
            • peste
              peste commented
              Editing a comment
              Hey!!! ...please post in English, what you didn't understand....
            #66
            HP EliteBook 845 G8 Notebook PC (545Y2EC)
            Become a Badcaps supporter
            Thanks to all supporters.
              Could you remove my bios pass?
                Serial number ? This is rules of forums.
                  HP EliteBook 845 G8
                  ProdID 1W3K6AV
                  SN# 5CG20742JJ
                    HP EliteBook 845 G8
                    ProdID 1W3K6AV
                    SN# 5CG20742JJ
                    CT Number_6LGWR0JVTFY40I
                    Serial_5CG20742JJ
                    Product_1W3K6AV
                    Feature byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPgSguhKjhk8mEn7nWngpD.gG
                    Build Id_21WWLCCT601#SABB#DABB
                      Thank you so much hoaca388
                      It works fine
                        help me to unlock hp 845 g8
                        S/N 5CG3072MS7
                        THANKS
                          I also have a Elitebook 845 G8 AMD and a few questions about dumping the bios/ec chip.
                          Is the EC chip on the backside (keyboard side)? I only could recognize a Winbond 25Q256JVEN behind the cover.
                          I tried to dump the IC data from the chip, but the Neo Programmer 2.2.0.01 only have a 25Q256JV chip selectable is that bad?
                          And my third problem is, that the IC not responds (I think there is not a contact between the flashing clamp of the CH341a). Is there any cheap programmar or clamp or should I try to desolder the chip?
                          Thank You
                            According to an ebay auction, this is the backside of the motherboard:
                            But I could detect any Bios/EC Chip... Does anybody where the chip is located?
                              Hello
                              Please help. My HP Elitebook 845 G8 has error "HP Endpoint Security Controller Problem".
                              Model: HP Elitebook 845 G8
                              Serial: 5CG20266ZJ
                              BIOS file attached. Thanks a lot
                              HP_845_G8_BIOS.rar
                                Good afternoon, could you help me activate absolute persistence module permanently disable.
                                thank you
                                Hp 845 G8
                                SN 5CG2473KSH
                                  thank you
                                  Hp 845 G8
                                  SN 5CG2473KSH
                                  Try
                                    Originally posted by hoaca388 View Post
                                    Try
                                    Thank you very much perfect work
                                      please help to unlock hp 845 g8
                                      sn 2TK2160KLL
                                      U366
                                        sn 2TK2160KLL
                                        U366
                                        Unlocked
