I need la-h325p bios please
    Re: I need la-h325p bios please
    Originally posted by sundeon View Post
    Hi! I need my bios fixed, can someone help me? Turns on no display
    Hp 250 g8 fpw50 LA-H325P Ver: 1.0
    sn: CND1431TLZ
    Here is my backup
    Read post #17
    Become a Badcaps supporter
    Thanks to all supporters.​
      hi! i need my bios fixed,can someone help me ? turns on no display
      HP :15-dw1239nia la-h325p rev :1.0
      SN :CND1345BD2
      HERE IS MY BACK UP
        Originally posted by Tosebeee View Post
        PLS I NEED HP 15-DW1239nia la-h3259 rev:1.0 bios . mine display problem
        Read the rules at post #15 .
          here is my back up
              pls anyone who can fix bios no display
              Hp 15s-du0110tu FPW50 LA-H325P
              • hoaca388
                hoaca388 commented
                Editing a comment
                Serial number ?
              #27
              SN :CND1345BD2
              HERE IS MY BACK UP
              BID : 085F5
              DMI : 3C7000h -> 3C900Fh
              WINDOWS KEY : 3C5000h -> 3C503Fh
                please i have this hp laptop with the board number LA-H325P with password..
                the chip is 4mb.. i have try other ways,but password wont remove.
                please me to unlock.
                S/N CND13355CR
                Thank you
                  SMDFlea commented
                  Editing a comment
                  Your BID is 085F5 ,use the virgin bios at post 29 .The DMI is at the same offsets,if you still can`t use a hex editor use HP Bios Config Utility to add the DMI. HP BCU can`t add a windows key though.
                #29
                Hi All need bios Hp FPW50 LA-H325P REV 1.0 i tried post #6 but same issues 5 long beep then 3 short its bios corrupts signal i attach dump bios backup anybody have 100 percent working plz share
                Hello aijazli, where you able to sort this issue on your hp FPW50 LA H325P REV 1.0 2019-01-18. mine have same 5 caps long flash and 3 short ones. Pls I will needed the bin if yours worked
                Hi friends, please help. Turns on, no caps lock codes but no display. I try some bios but no changes. Bios version 085f5 F63, Serial CND3192ZNH.
                I can program EC ENE KB9022Q
                Thanks in advance
                • Vesko356
                  Vesko356 commented
                  Editing a comment
                  Thread merged.
                #31
                Thanks in advance
                Post #6 bios is working! Thanks
                TIP: If "manufacture programming mode is in unlock mode" appear when power on, use HP tool https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html
                  Hello all
                  i recive this hp laptop with caps lock 5 slow and 3 fast blink error which indcate bios error
                  the motherboard numper is FPW50 LA-H325P1 REV 1.0
                  sn CND131133V
                  the laptop seems to be bios programed before so i read the bios chip and attached the file
                  but i think i have to modify this file or it culd be the wrong file programed by some one else
                  so is there any way that i can find the right bios file because i try some bin files with the same result
                  i read that i need to modify DMI and some another things in order to be able flash the bios
                  thank you all in advance
                    Originally posted by hoaca388 View Post
                    Re: Fpw50 la-h325p rev 1.0 bios
                    HP Notebook - 15-dw1213nia
                    TESTED OKK Thank you so much
                      fpw50 la-h325p rev 3.0 bios please mine is 4MB
                      FPW50 LA-H325P REV: 3.0 2021-10-21
                      HP Notebook - 15-dw1208nia
                      SN:CND2120XGT
                      File Size: 4MB
                        SN:CND2120XGT
                        File Size: 4MB
                        Thread merged. The bios should not be 4MB ,choose the chip manually,don`t use autodetect. What is the chip part number,which programmer are you using and the software version .
                          I'M USING EZP2010 FIRMWARE VERSION 3.0
                          BUT YOU HAVEN'T GIVEN ANY FILE TO USE YET
                            If you can`t answer all the questions then i can`t help. As i said the the bios should not be 4MB, so you`ve either got the wrong 4MB bios chip on the board or the programmer has wrongly detected the chip. Don`t use ALL CAPS in your reply please !
                              I need the bios of LA-H325P model: 15-dw1504la
                              i can't find it
                                i can't find it
                                Thread merged.Post your backup and the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
