On Board Ram Disable via Bios Editing
    Try this, and report please
      Thank you very much. It works correctly. Thank you for your help. Could you explain the process?
        thanks,
        i use sort of SMDFlea way.
        https://www.badcaps.net/forum/troubl...opydmi-scripts
        Not working on all bios.
          Hi, Lenovo S540-14IML, motherboard LA-H082P, internal ram is not good, giving errors and bluescreens.
          Can you disable it?
            SMDFlea commented
            Editing a comment
            Post the laptop serial number ...
          Can you disable it?
          try
            Originally posted by rex98 View Post
            try
            Thank you, it is working.
              Originally posted by shugu1701 View Post
              hello can someone plz disable onboard ram, i have 1 shorted ddr5 chip and cant find it anywhere and i have 1extra ram port not soldered.
              asus rog gu603zw
              sn: NANRKD003711429
              Do you still have this laptop.
                SMDFlea, perhaps you'll find someting here that will help you
                https://winraid.level1techs.com/t/as...over/102549/11
                  yes i still have it
                    yes i still have it
                    Ok, can you try these 2 bios.
                      thank you, i tried both but not working, cpu not getting warn, it was getting warm with original bios :/
                        Oh well, i tried
                          Oh well, i tried
                          thank you , i maybe finnaly found a ddr5 stick that may have the right chip on it i will see then
                            can any one disable onboard ram with SPD removal tool?
                            lenovo l340-15api
                            nm-c101
                            sn: pf29yzvh
                            • peste
                              peste commented
                              Editing a comment
                              post merged..
                            lenovo l340-15api
                            nm-c101
                            sn: pf29yzvh
                            try..
                              can any one disable onboard ram.
                              lenovo T490
                              nm-b091
                              sn: PF25BYJN
                                try this and report result, please.
                                  thank you, i tried but not working.
                                    NM-C711
                                    Lenovo V15IIL
                                    S/N: S/N: PF1CMFF1
                                      NM-C711
                                      Lenovo V15IIL
                                      S/N: S/N: PF1CMFF1
                                      hi try
