i need build bios asus Q409z gen 12
    please give me
    Re: i need build bios asus Q409z gen 12
    Originally posted by tdelfy View Post
    please give me
    did you check the warranty
    Model: Q409ZA-KM161W
    Distributor: BEST BUY PURCHASING LLC
    Country: US
    Warranty start date: 2022-06-26
    Warranty end date: 2023-07-21
    Warranty extension:
      Thank you sharing。
        May i Ask, Is it possible to build this bios without any error ?
        i got this laptop problem no display and fan not spinning. Then finally found working bios, now i have two working bios with different problem. Bios from post 1 working with late display and i must install IRST driver every boot to detect nvme, The other bios that i attach, have late display but not detected nvme even i install IRST driver. Any advice ?
        Laptop : Asus Q409ZA ( UX3402ZA )
        Motherboard : NB5936 V.3
        S/N from bottom case sticker : N3N0LP01C142106
        This is the best QR code pict from the board i can take cause i don't have microscope
        Thank you
          Thank you
          Read the rules before posting:
          Add your bios backup even if it's corrupted, serial number and photos of the motherboard with the QR code.
          Become a Badcaps supporter
          Thanks to all supporters.
            Thank you
            Here's your New BIOS, try it and let me know the results.
            If you can't see the NVME when you are trying to reinstall OS, go to BIOS Menu, search for Intel VMD and disable it.
            all donations are welcome,
              Thanks, i'll try tomorrow and give the result
                I think your bios fix the IRST driver from before that detect NVME automatically. But still late display, maybe ME region still need to be clear. But since it's new gen i didn''t find how to clear it. And 1 problem is i can't install audio driver, i'll try searching for solution. But at least it can boot normally when turn on, thank you for your help
                  I have already Cleaned the ME.
                  How much time the device takes to show an image? Have you checked the CMOS Battery (if it's exist in this model)? If there is no CMOS Battery, are you sure the Main Battery is fine?
                    Engineering BIOS if anyone needs in future
                      I just want to thank Lisa Su for posting this BIOS. Absolutely saved my laptop from a no audio/boot hang issue.
                      I'm still under warranty with two weeks left, but don't want to deal with shipping/diag fee/etc. just to get a replacement laptop from ASUS.
                      My cheapy 3v3 modified CH341A (black) programmer worked out great. NeoProgrammer knows that it's connected, but doesn't recognize the IC (XM25QH256C). I was able to choose the IC's previous revision from the IC list (256B) and read/verify/write successfully.
                      Thank you thank you THANK you.
                        does any one have Schematics or boardview available ? my laptop are no keyboard backlight after flash new bios.
                          read this..
                            I'm notice that about this model after program new BIOS . keyboard backlight are not function. does everyone have any solution? I need help please.
                              https://www.badcaps.net/forum/showpo...43&postcount=5
                              4.4. Asus
                                my old bios backup has give me on me analyzer
                                "Error: Detected CSE Extension 0x16 with wrong Partition Hash at FTPR > FTPR.man!"
                                can you clean my backup please?
                                  You must post the serial number serial number !
                                  Also post a picture of the QR code,like the one at post #4
                                    my sn is: N3N0LP02A42912G
                                      my sn is: N3n0lp02a42912g
                                      mmmmmmmm
                                        Originally posted by hoaca388 View Post
                                        mmmmmmmm
                                        thank you for interest,
                                        but still no display.
