Acer nitro 5 an517-52
    Hi
    Need Bios for ACER nitro 5 AN517-52-55AW
    La-K862P
    not work
    Power button work, lights up, keyboard lights and cycle/reboot
    no display, no caps lock
    thanks
    edit :
    find this, maybe good ?
    https://www.badcaps.net/forum/showth...light=La-K862P
    Re: Acer nitro 5 an517-52-55aw
    Originally posted by Maxpower3 View Post
    Hi
    Post your bios backup,and the serial number on the case
      ok work with other bios
      SN NHQAWEF009120058E43400
        Nitro AN517-52
        Become a Badcaps supporter
        Thanks to all supporters.
          Originally posted by hoaca388 View Post
          Nitro AN517-52
          AN517-52 Part Number: NH.QAWEF.009
          W 370000
            AN517-52
            W 370000
            why big eyes ^^
              why big eyes ^^
              surprised that hoaca388 missed something
                Thank you. you are wonderful SMDFlea and Hoaca388
                    I have same issue on Acer Nitro 5 AN515-55-75NB
                    Motherboard GH51M LA-K862P REV 1A
                    MB was shorted, so I changed 2 shorted mosfet (PQB11 and PQZ1).
                    Now power button work (turn on and turn off), lights up, keyboard lights, fun spinning normal with 1.40 Ah absorption and every voltages are good on every coils.
                    No display, no caps lock (when i press caps lock it not change, seems blocked).
                    Obviously I cleared and reseated memory RAM stick and tried on external monitor by HDMI.
                    I flashed three BIOS downloaded from this site but without success, maybe these files are not good for my MB model, so I attached my BIOS file and this is serial number: NHQB2ET00A1100CBC43400
                    Thanks in advance,
                    FabyJ
                      Originally posted by fabyj View Post
                      i have same issue on acer nitro 5 an515-55-75nb
                      motherboard gh51m la-k862p rev 1a
                      mb was shorted, so i changed 2 shorted mosfet (pqb11 and pqz1).
                      Now power button work (turn on and turn off), lights up, keyboard lights, fun spinning normal with 1.40 ah absorption and every voltages are good on every coils.
                      Obviously i cleared and reseated memory ram stick and tried on external monitor by hdmi.
                      I flashed three bios downloaded from this site but without success, maybe these files are not good for my mb model, so i attached my bios file and this is serial number: Nhqb2et00a1100cbc43400
                      thanks in advance,
                      fabyj
                      here
                        Hi hoaca388 and thanks for files!
                        First I flashed BIOS with TL866A, as this minipro not detect XMC chip model so I selected W25Q128FV chip model disabling Check ID but same issue.
                        Then I flashed EC, when MB start keyboard light colour has changed, now is white, before flashing EC was red and absorption increased up to 1.56 Ah, when close display absorption decrease to 1.25 Ah but same issue, no video
                        Maybe TL866A is not good?
                        Or something is wrong on MB?
                          MB: GH51M LA-K862P REV. 1A
                          SN:NHQ3MET0169340C0F63400
                          GPU:GN20-E3-A1 GeForce RTX3060M
                          CPU:SRH8Q I7-10750H
                          I fixed short on PQZ3 VSW3_VCORE.
                          Now laptot power on but black screen.
                          I try bios dump but same issue.
                          On coil vcc_core ithere is 0,75V
                            CPU:SRH8Q I7-10750H
                            Nitro AN515-52
                              Hi Guys.
                              Need help please.
                              History:
                              Laptop had shorted dual mosfet on vcc core.
                              After removal of mosfet i got fan spin, power cycle, kb light, no display.
                              With new mosfet in place -> no change.
                              Today my t48 arrived and i was able for the first time to read a bios chip without desoldering (i used clip).
                              I may have damaged the bios chip (???) because after reading verifying and saving the dump laptop only gives me 5 sek blue power led.
                              No fan spin, no kb light no power cycle no display.
                              All voltages (19, 5, 3,3, 1,8) present.
                              Sidenote:
                              My bios chip only gets vcc voltage after pressing power button. Is this normal ?
                              Need advice please.
                              Thank you for your time !
                              LA-J891P Rev. 1A
                              ANS517-52-74PR
                              S/N: NHQ8KEV0030291408D3400
                              SNID: 02908206134
                              Orig. Bios attached
                                Long story short: I tried to install the BIOS Update 2.08 on my Laptop which had version 2.01 on it beforehand. Did not make a backup. The Update failed, it froze in place and stayed that way for around 2 1/2 hours, after which I powered it down, I basically accepted my fate at that point.
                                Current situation: laptop powers on, keyboard flashes, fans spin up, screen stays entirely black. BIOS Flashing doesn't work in my tries.
                                I've had a history of it behaving weird. Around 9 months ago it would freeze randomly after transporting it in a backpack for 2 hours on public transport and was basically unusable. Wasn't sure what it was, so I just left it since I did not have much time to use it anyway. Installed Linux Mint on it a month ago and it ran fine - except Fan speed control was impossible using Linux, so it cooked itself on any game it ran, normal use was fine. Switched back to Windows 10 and downloaded NitroSense again, after that, everything ran fine. Heard of ending support for Win10, so I downloaded the BIOS v2.08 from Acers Website to add Win11 Support. You know the rest.
                                What I've tried:
                                • Removing battery, CMOS battery and all storage and ram and slowly adding them back one by one during each boot.
                                • Flashing various BIOS I found on the ACER Website and online forums. Laptop spins fans at full power for a bit, but after no more than 10 seconds, it shuts off and behaves like in [Current Situation]
                                I have read through some of the other pinned Posts on the forum here, but I am not sure where to go next. I have seen others with a Nitro 5 get good assitance on this site, so I am asking here. I am willing to learn how to measure voltages and solder if needed, since I have some of the required materials at work and at home already.
                                Details:
                                AN517-52-7363
                                S/N: NHQAWEG003113090E33400
                                GH51Z LS-K854P Rev:1.0
                                • peste
                                  peste commented
                                  Editing a comment
                                  merged post..
                                Sorry, mobo is GH51M LA-K862P, Rev.:1A , the other board is something keyboard related...
                                  Hello i need a BIOS and EC BIOS for this Notebook:
                                  Model: Acer Nitro 5 - AN517-52-77DS
                                  Mainboard: FH52M LA-J891P Rev: 1A
                                  SNID: 02502227234
                                  I have No dump of the old Files, need with Clean ME because i installed a new PCH.
                                  Thanks for the Help
                                    SMDFlea commented
                                    Editing a comment
                                    Thread merged.
                                  SNID: 02502227234
                                  Thanks for the Help
                                  Forget to Post my S/N:
                                  S/N: NHQ8KEV001025057003400
                                    please try this one there two bios inside please try those if none works feedback
