Dell Latitude 5420 Bios Password 8FC8
    Is this related to operating system.because i havent tempered with the ssd card the whole process
      check in bios setup
      are you able to see hdd (m.2/ssd/nvme) in bios
      if yes than chk bios setting boot sequnce/secureboot/uefi
      if you cannot see storage in bios setup than possible it could be a bios issue
        In the boot configuration settings i only have one option(uefi https boot place holder)
          on first page { overview }
            What about it
              ANYONE ELSE CAN HELP.my dell 5420 had a locked bios passcode.my original dump was corrupted.i flashed with the following file and icould access the bios setup very well except that theres no nvme detection.the laptop has got a new service tag after flashing the bios..bord model GDF40LA-K491P REV 2.0.anyone can help me with a full working bios file
                did you write this file from post 528 you posted and what is the status ?
                  i got the file from https://*****/***** HAVE ATTACHED PICS OF MY PC NOW AFTER FILE
                    Vesko356 commented
                    Editing a comment
                    Do NOT post in all caps.
                    Do NOT post external links!
                  try. in first boot put Service tag.
                  Last edited by Vesko356; 01-22-2024, 04:18 AM. Reason: Quoted external link removed
                    the file okay but cant write service tag to goes to automatic repai before i write tag
                      Here i build a new bios for you now everything should be ok
                      add your laptop service tag manually from bios setup
                        Hi got this latitude 5420 ST: 8Q9C3D3 board 2FM7C if anyone can unlock it for me pls
                          Unlocked
                          Become a Badcaps supporter
                          Thanks to all supporters.
                            Thanks team all worked well.unlocked dell running smoothly.qayyum thanks
                              Hello, I've recently purchased a Dell Latitude 5420 (Model code:p137g) and the previous owner has an admin password set locking me out of the Bios and effectively out of the laptop altogether. Is anyone able to help as haven't had much success searching the net for answers. Thanks.
                              Hello, can you please help me delete the password on my Dell Latitude 5420 laptop, thank you.
                              service tag : 687M1J3
                              SUFFIX : 8FC8
                                try
                                  Originally posted by qayyum786 View Post
                                  try
                                  THANK YOU VERY MUCH, IT WORKED PERFECTLY
                                    Vesko356 commented
                                    Editing a comment
                                    Do NOT post in all caps please!
                                  Good evening Hackers
                                  Please ..... can anyone help me to remove BIOS password.
                                  DELL Latitude 5420 0M51J7/F3GZYD3/CNCMK0016N492E
                                  CPU: i5-1145G7 11th Gen
                                  Bios: Ver. 1.30.0
                                  MD: 06/25/2021
                                  ESC: 32861684919
                                  ST: F3GZYD3-8FC8
                                  Bios IC: XM25QW256C
                                  Thank you very much
                                    Bios: Ver. 1.30.0
                                    MD: 06/25/2021
                                    ESC: 32861684919
                                    ST: F3GZYD3-8FC8
                                    Bios IC: XM25QW256C
                                    Thank you very much
                                    try
