ASUS G531GV ROG bios dump
  • btomce
    • Nov 2020
    • 71
    • lt
    Looking for clear ME bios dump G531GV
    My is not work.
    In Attach
    1 My is not work.
    2 Update from site
  • cacla
    • Apr 2015
    • 444
    Re: ASUS G531GV ROG bios dump
    here
    • ongobongo
      • May 2023
      • 63
      Hi guys,
      i need help with a possible corrupted bios.
      I have an asus rog strix g531GV-AL022 which shows only black screen. As CPU/GPU get warm and keyboard animations work (and i don't have any shorts on the power rails) I suspect the bios to be corrupt.
      I already dumped the original BIOS with CH314. I then tried reflashing with several versions, first the original from the website (.307-file which is 2KB bigger than the dump which didn't work). I then removed the encapsulation by opening the .307-file with UEFITool NE and extracting the UEFI-image, which lead to the correct file size but ended in not working at all, laptop is not powering on at all with this.
      I also tried some bios versions I found here, but they don't work either.
      Attach you'll find both my original dump and the .307 version from the asus website.
      Details of the machine:
      Sn: K7NRCV034304297
      CN: KLK5
      Board is:
      G531GW r1.6
        SMDFlea commented
        Editing a comment
        Thread merged.There`s an asus service bios at post 2, copy your DMI from your backup to it.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12425
      Originally posted by ongobongo
      Hi guys,
      Sn: K7NRCV034304297
      CN: KLK5
      Board is:
      G531GW r1.6
      zzz
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
