Need Lenovo IdeaPad 3 14ITL05 board NM-D461 Dump
    Hello
    please need bios dump for laptop Lenovo IdeaPad 3 14ITL05, motherboard NM-D461
    Backup bios.
    Re: Need Lenovo IdeaPad 3 14ITL05 board NM-D461 Dump
    Originally posted by airblade View Post
    Hello
    Backup bios.
    kumusta
    Here you go
      salamat po,
      thank you working 100%
        Motherboard rev?
          Lenovo Ideapad 3 14ITL05
          Help remove bios lock Ideapad 3 14ITL05
          There is two bin file backup 8mb and the 16mb
          TIA...
          Board info:
          Hs45a/hs55a
          Rev: 1.0 NM-D461
            Re: Lenovo Ideapad 3 14ITL05
            TIA...
            Board info:
            Hs45a/hs55a
            Rev: 1.0 NM-D461
            bios extracted from Lenovo site update..
            bios for ideapad 3-14ITL05, ideapad 3-15ITL05 laptops
            DMI is in the 16MB bios
            DMI 422000 - 423FFF
              DMI 422000 - 423FFF
              Thank you for your help
                HS545/HS55A
                NM-D461
                REV 1.0
                I have bios blocking problems with this model, can someone help me to remove it?
                  Originally posted by Kuroneox View Post
                  HS545/HS55A
                  NM-D461
                  REV 1.0
                  use post#6
                    HELP Lenovo IdeaPad 3 14ITL05
                    hello
                    need working bios dump. after i flash dump file here https://www.badcaps.net/forum/showthread.php?t=110233
                    cant boot and no display power light blinking only laptop is bios password only anyone could help me please thannk you.
                    heres my backup bin
                      Re: HELP Lenovo IdeaPad 3 14ITL05
                      Originally posted by gsmcaleb View Post
                      hello
                      heres my backup bin
                      you have everything you need at post #6, if you write both bios chips correctly and the problem was the bios, it will surely work for you...
                        Hi, I need some help with a Lenovo Laptop.
                        S/N: PF4372D0
                        MTM: 81X700FGUS
                        Factory ID: JVHFC1
                        MO: PF9XB2B24003
                        HS45A/HS55A NM-D461 Rev: 1.0
                        It's turning on and everything okay but when you press any key on the keyboard, it sends the signal twice, i mean when you press the key it sends the letter and then when you release the key it sends the same letter again, i.e in the Notepad app when you press and release "a" key you get "aa" in the app.
                        This issue happens in every app, even in the BIOS SETUP, (i.e. whith the arrows keys), and pressing the key slow or fast, same issue.
                        I already replace the keyboard with one that works good on other laptop.
                        I inspect the board (Keyboard controller area) and everything looks okay.
                        So i suspetc it has a failing BIOS.
                        Here is the backup bin files.
                        Please I really need some help with it.
                        Thanks in advance.
                          S/N: PF4372D0
                          MTM: 81X700FGUS
                          Factory ID: JVHFC1
                          MO: PF9XB2B24003
                          Thanks in advance.
                          Try if it will not resolve the issue with bios you may try to change IO controller
                            Thank you qayyum786. I tried your bin files and same issue, I´m trying to get a replacement for the I/O controller. Thank you!
                              good day sirs. when i create a dump file for this model i only get 8mb of BIN. Where can i use the 16mb? My unit auto restarts every 10 seconds. I already flashed the 8mb BIN. TIA
                                Hello, thanks a lot for providing us with dump files from working and unlocked Lenovo laptops.
                                I'm a computer technician since 2003, so I'm used to deal with a lot of old and new issues related to this area of work.
                                But I must recognize that if it weren't for places like this forum, my job would be much harder to get results.
                                So this THANK YOU goes for all of you that makes it possible! You're awesome!
                                Now, my issue:
                                I received 2 laptops these days and one of them was locked by bitlocker, that awful thing from MS. It is the model we treat in this thread.
                                I've just re-flashed the BIOS/UEFI chips with the dump files provided by gbuniva but it doesn't detect the SSD NVME nor SATA anymore.
                                Should I try to re-flash with the files provided by qayyum786?
                                I'll try it anyways as I don't have too much time. I'll keep you posted.
                                The model and part number: Lenovo IdeaPad 3 14ITL05 / MO: PF9XB2523005 / MTM: 81X700FGUS / MFG DATE: 05-23-2023 / FACTORY ID:JVHFC1
                                Thanks in advance to anyone who can help me to deal properly with this issue.
                                God bless you.
                                PS: I found a barcode on the MB that has this writen: 1696030203087 4511ET12301 HS45V 10B2 1C_2022-05-19
                                  what kind of flasher/programmer you guys used for this kind of board?
                                    see what bios chip it has and what programmer this chip has in its database..
                                      Thanks Friends !
                                        DMI 422000 - 423FFF
                                        THNAKS SER.
