Dell XPS 9310 GDA30 LA-J143P bios repair please
    The Mainboard model is: LA-J143P
    When im trying to boot i get a 3x amber and 6x white error without any Display output. I also cant get into the BIOS or recovery mode.
      SMDFlea commented
      Editing a comment
      Thread merged
    try
      Thanks for the file and sorry for my late response!
      I have tried the BIOS and the flashing light stopped but the Laptop still has the same issue.
        dell xps 9310 2 in 1 LA-J851P
        st: 6PZC593
        The condition is that if you use it for a while, you will lose sevitag
        please help me!
          st: 6PZC593
          please help me!
          here try this rebuid and give feedback
            Currently it is working fine, I will test more, if there are errors I will respond, if there are no errors then it is perfect. Thanks a lot
              I need some assisstance with a BIOS repair, i try to fix 2xAmber, 4xWhite Problem.
              Dell XPS 13 Model: 9310 / P117G
              Mainboard: GDA30 LA-J143P Rev: 1.0 (A00)
              SVT: 6VT03F3
              The Extracted Bios:
              Thank you in advance.
                SVT: 6VT03F3
                The Extracted Bios:
                XPS 13 9310
                Service Tag: 6VT03F3
                Become a Badcaps supporter
                Thanks to all supporters.
                  Thanks alot. I accidently killed the chip during assembly soldering process. I keep you informed as soon as i get replacement part.
                  Best regards
                    Originally posted by hoaca388 View Post
                    XPS 13 9310
                    Hi Hoaca, sorry for the late response.
                    I have severaly issues related with the chip.
                    First, two series resistors were missing.
                    I had problems to erase, write the XMC chip with the T48 programmer (XGPROG on wine). I assumed my chip was gone accidently, but something was wrong with the XGPROG under wine.
                    Now, i fixed that with minipro it much more reliable. (I was capable of earsing the chip, blank checking it, writing it the image and reading it back. I calculate the MD5sum over the in and output image and it seems fine).
                    Bios has following symptons on my computer:
                    When Turning on:
                    * Capslock lights up
                    * No Dell logo
                    * No Front LED indicator.
                    * No reaction on F2 / F12 inputs.
                    * Power Management Controller handles 20V fast charge and charges the battery (Measured via USB-C Meter).
                    Is it worth to mention that i don't have 2in1 version of that notebook?
                    Do you have another bios to try?
                    Best regards, Diego
                      Dell XPS 13
                      Reg Model P117G
                      ST: 6FJ1M53
                      EX 13999674711
                      my laptop stuck in Dell logo. How to solve this? I use ch341 programmer ..please help me
                        Originally posted by darmanto goh View Post
                        Dell XPS 13
                        Reg Model P117G
                        ST: 6FJ1M53
                        EX 13999674711
                        Your model is the 9300 . Please post your request in one of the XPS 9300 related threads, use the forum search engine to find one, and post your bios backup as well as all the other info
                          Hello, I've got a Dell XPS 13 9310 that shows the Dell logo and gives 2 amber and 4 white blinks.
                          Service Tag: CKV20F3
                          Motherboard: GDA30 LA-J143P Rev 1.00 (A00).
                          Can you fix BIOS, please?
                          org bios:
                            Hello try this file perhaps it help's .... Good luck
                              @Markus1741 Thanks for the file, much appreciated!
                              I tried several BIOS versions, and during one of the attempts, I damaged a resistor near the BIOS. On the boardview, I can see that it's resistor RC104. Now I only have 5V; it doesn't jump to 19V. On the thermal camera, I can see the GPU heating up slightly when powered on. Looks like it's game over.
                                My Dell XPS 9310 motherboard GDA30 LA-J143P rev 1.0 has 2 amber + 4 white flashing LED.
                                ST : DN80YD3
                                EX : 29702373879
                                Can you fix BIOS ?
                                Thanks.
                                  I HAVE A DELL XPS 9310 LA-144P WITH A DISPLAY THAT COMES AND GOES
                                  NO SERVICE TAG
