Microsoft Surface laptop 4 UEFI password
    I have a corrupted bios chip after an update.
    If anyone has a dump I would be very grateful.
    Model:
    Microsoft Surface 4 (2021) Model 1950
    Intel Core i5 11th Generation
    512GB SSD
    16GB Ram
    Bios-Chip: W25R256JWPQ
    S/N: 024302314457
    Thank you
    • peste
      peste commented
      Editing a comment
      merged post..
    HI dear,
    Surface laptop 4 1951
    Sn: 036094623057
    First the black screen system update bar showed and wouldn't complete(due to power off the system) , then the system turned off. After that, the blank screen and "backlight on", then the display wouldn't show surface logo, but the CPU got warm. The original bios have been enclosed. Please check the file and give me the proper bios.
      Originally posted by giliy52480@degcos.com View Post
      HI dear,
      Sn: 036094623057
      Try
        Originally posted by minhdigital View Post
        Try
        I tried this but still no disp.
        This surface laptop had a backlight flickering. I put some heat on the edp socket and some capacitors around (I think cold solder occurred) the socket, but after some days the problem came back. Then, immediately after turning it on, the system firmware update appeared, and during the test for the edp connector, whether it was broken or not, the system turned off and finally, when it turned on, the backlight was on, but no disp. When I pressed the F4 key to go to the bios, the display had some horizontal line on the screen with a backlight but no disp (the picture enclosed) and the CPU got warm. This line's place changed after the restart.
          Please help to remove bios pass
          Model Surface Laptop 4 1951
          S/N: 042177713557
          Thank you!
            I have a surface 4 laptop (model 1951) which I cannot get past the UEFI/ BIOS system password as I do not have a record. Cannot change the boot sequence in the UEFI given no password, and cannot access windows as do not have the bitlocker key.
            Would anyone be able to help guide me through what to do - have read various posts about scripts, certificates, BIOS dumps, but really don't have a clue how to do this. Have tried opening and taking out the SSD, but this did not reset the UEFI password. I cannot locate a CMOS style battery, so assume it doesn't have one.
            Have all my data stored on network drive and onedrive, so quite happy to erase the whole thing - if only I could...
              post S/N, full name and model, motherboard model,post the original contents of the bios chip..etc.
              you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                S/N: 042177713557
                Thank you!
                Hi!
                I succesfuly removed UEFI pass, now i need to remove SEMM certificate but i don't know how to start
                Please help me
                Thanks!
                  Hi!
                  Please help me
                  Thanks!
                  invalidate IPCVN
                    Originally posted by volinakis View Post
                    invalidate IPCVN
                    it works perfectly!
                    thanks !
                      it works perfectly!
                      thanks !
                      Cu placere!/ you are welcome
                        Hi, Im new to all this and not sure if this is the correct place but im looking for password for my surface laptop 5
                        Model 1951
                        SN 0F00AAB23303FB
                        not sure what else you require.
                        Please help
                        • peste
                          peste commented
                          Editing a comment
                          post merged..
                        Model 1951
                        SN 0F00AAB23303FB
                        Please help
                          I wonder if someone can help, I have a surface laptop 4 model 1951 which i don't have the UEFI password for.
                          I would like to get it reset if possible and know I need to provide information and the bios backup. I'm currently having issues getting a bios backup and wonder if anyone can assist, I've checked the guides but there doesn't seem to be specific information for the surface laptop.
                            Surface Laptop 4
                            Model: 1951
                            Serial - 024426322557
                            Can anyone help me clean this? Many thanks in advance.
                              hi can anyone remove this please ?
                              1951
                              serial - 024426322557
                              post merged...
                                1951
                                What remove ?
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                  sorry the bios lock password
                                    Unlocked
                                      sorry , does not sdeem to let me change UEFI and boot from usb , password still on
                                      regards
