bios password Lenovo L440
    HI .can you remove password from lenovo l440
    thanks.
    Re: bios password Lenovo L440
    thanks.
    Here's your Patched file, you will need to read this tread carefully.
    https://www.badcaps.net/forum/showthread.php?t=87588
    all donations are welcome,
      thank you it's working
        Would someone be able to remove this bios password please
          You can patch it yourself using the available unlocking software in the forum.
          By the way,your backup is shit, read this https://www.badcaps.net/forum/showpo...40&postcount=2
          Originally posted by piernov View Post
          Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
          Please read the rules before posting,you must always include the laptop serial number,amongst the other rules.
          You MUST:
          Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
            Lenovo L440 Bios Password
            Serial number R90FM6T6
            Kindly remove the password on the attached bios bin.i have tried autopatcher but my patched file didnt work.Thank you
              did you find the solution for that?​
              https://www.badcaps.net/forum/troubl...09#post3312009
              try
                lenovo L440
                S/N: R9-0HT3ZX
                help me to unlocked the password or help me to patch the file.
                i have tried to patch the bin file, is not working
                  thank you every one.
                  i later solved it, i make used of post #7 file
                  mind you, what i experienced is.
                  Patiently
                  first boot will takes like 2-3 minutes to display immediately press F1
                  Next press any key or 123 on password then follow the instruction
                  STEP 1: Flash and replace current BIOS with the generated patch file
                  STEP 2: Boot the machine
                  STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                  STEP 4: Enter any character when asked for Supervisor Password
                  STEP 5: Press enter when it shows Hardware ID
                  STEP 6: Press space bar 2x when asked
                  STEP 7: Turn off machine
                  STEP 8: Restore original BIOS
                  STEP 9: Reset BIOS settings to factory default
