HP ProBook 650 G8 BIOS Admin Password
    Re: HP ProBook 650 G8 BIOS Admin Password
    Originally posted by compuline View Post
    hello my friends
    i wanna remove password hp probook 650 g8
    ec file
    read post #18
    Post 16MB as well
      HELLO MY friends
      I WANNA REMOVE PASSWORD HP PROBOOK 650 G8
      EC FILE
      Upload MAIN BIOS 32MO
        hello all . could you please help with the unlocking of this HP
        HP ProBook 650 G8 i3-11th gen
        Board Number : DAX8QMB38A0_REV:A
        MODEL : A8QE
        Prodid : 1Y5K9AV
        S.N : 5CD2013045
          MODEL : A8QE
          You must post the laptop serial number
          RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
          https://www.badcaps.net/forum/troubl...sting?t=103570
          Have you tried RCUnlocker, you`ll find it if you read the bios guides
          BIOS guides, methods, resources and tools
          https://www.badcaps.net/forum/troubl...rces-and-tools
            thanks for your fast replay
            info add to post
            also i try both RCunlocker and HPunlocker and not working
            RCunlocker say wrong chip try reading and unlocking 16MB chip
              SMDFlea commented
              Editing a comment
              The 16MB chip is on the other side of the board, probably hiding under the plastic sheet
            #26
            info add to post
            Unlocked
            Become a Badcaps supporter
            Thanks to all supporters.
              Originally posted by hoaca388 View Post
              Unlocked
              thanks for your help it worked
                HI every one i have hp probook 650 g8 s/n# 5CD221HB8P dax8qmb38a0 rev A problem is no dispaly
                  HP ProBook 650 G8 Notebook PC (596M7EC)
                    thanks for repaly i check this file but not work same problem
                      Check hardware.
                        hi, pls help unlock this bios.
                        Hp ProBook 650 G8
                        sn 5CD1389BWB
                        pcb DAX8QEMB8DO
                        QR 04G0
                        Great plan, there is not enough memory on the server, external links are not allowed.
                        Hp ProBook 650 G8
                        sn 5CD1389BWB
                        pcb DAX8QEMB8DO
                        QR 04G0
                        only flash this main do not touch the EC.
                        In first boot be patient, press f10 apply factory defaults and exit. after restart press f10 again then reset security settings to defaults.
                        Use MPM TOOL/bcu.
                        Serial Number: 5CD1389BWB
                        Product Number: 3S8T7EA#UUW
                        CT Number: PLEHE048JFN27Z
                        Description: HP ProBook 650 G8 Notebook P
                        build_id: 20WWISDT601#SUUW#DUUW
                        Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdUdpdqeMfAfPguhKhkjhk8mEmVn7nVpD.7m
                        MAC Address: 6C-94-66-CE-A0-5E
                          Use MPM TOOL/bcu.
                          There is a problem with the Endpoint Security Controller on the unit.
                          any ideas or suggestions?
                            SMDFlea commented
                            Editing a comment
                            Cleaning the ME firmware can sometimes fix that issue.
                          #35
                          AAA
                            AAA
                            same
                              same
                              Try
                                Originally posted by RJ_TECH View Post
                                Try
                                The Embedded Controller MUD data does not match bios MUD...
                                the client decided to pick up the laptop, thank you all for your help.
                                  Good Day
                                  i have a HP PROBOOK 650 g8 motherboard with wrong DMI information.
                                  Motherboard is supposed to have 450 g8 DMI information.
                                  HP PROBOOK 450 G8
                                  Serial number 5CD1403024
                                  I have uploaded the bios that is currently on the machine.
                                  If you able to set the bios back to factory mode with no DMI on it. I will appreciate very much
                                    Originally posted by mahlon simwnaja View Post
                                    Good Day
                                    HP PROBOOK 450 G8
                                    just change the description to your desired model. Use BCU.
                                    Serial Number: 5CD21021DP
                                    Product Number: 595Y8EC
                                    CT Number: PLEHH048JFJ0UG
                                    Description: HP ProBook 640 G8 Notebook P
                                    build_id: 19WWCFAT603#SACQ#DACQ
                                    Feature Byte: 3X476J6S6b7B7M7R7U7W7m7saBaEapaqauawbUbhdUdpdqfPfXhKhkj4jhk8.Y4
                                    MAC Address: 7C-21-4A-0B-F4-C3
