need bios dell inspiron 15 5502
    board number - MKB N TGL 8L MB 19861-1
    service tag - G3B6G63
    bios backup
    Re: need bios dell inspiron 15 5502
    bios backup
    Here's your new file, try it and give me the results.
    all donations are welcome,
      thank you so much sir...working perfectly
        You're Welcome. is there any problem, like refused to loading windows or show service tag message?
          Thanks for wasting hoaca`s time helping you in the other thread https://www.badcaps.net/forum/showthread.php?t=112844 .I told you in the PM i sent you yesterday to be patient but you couldnt wait, you had to post again. Next time you do that you will receive an infraction.
            so far no problem sir...all working like a charm...thank you sir
              dell Inspiron 5502 bios need
              hello friends i need your help again i'm looking for the bios dump of this dell inspiron computer
              I noticed it has 2 bios one 4mb and one 8mb
              thank you for your kind reply
                Originally posted by biosedit View Post
                Hi every one I need to know how to add or remove service taq in dell bin file
                Please remove service taq tts not accepting service taq
                INspiron 5502
                i don,t have service taq
                  SMDFlea commented
                  Editing a comment
                  post merged. Post the motherboard model number
                INspiron 5502
                BOARDNO
                19861-1
                  i am using this file for my dell same model but i cannot put my service tag and it always shows alt f to go to normal mode.....my service tag is:BYXBR93
                    You have to go into BIOS Setup in the first boot and insert your Service Tag then save and exit.
                    If you pressed ALT+F before insert the Service Tag, you will have to re-flash the BIOS chip again.
                      I need bios for Dell Inspiron 5502 when turned on, the screen remains black and beeps when the keyboard is pressed
                      Service Tag CC69V93
                        SMDFlea commented
                        Editing a comment
                        thread merged.
                      Service Tag CC69V93
                      Upload 16 MB chip.
                      Become a Badcaps supporter
                      Thanks to all supporters.
                        no power, using 0.04 ma current,
                        dell 5502 bios is broken i think can you help
                        backup bios;
                        Servis tag, HGW6P93
                        I solved with this post https://www.badcaps.net/forum/troubl...rd#post3245320
                        Originally posted by Chaminda4191 View Post
                        Dell Inspiron 5402-5409 and Vostro 5402-5409 models may encounter an issue where the service tag cannot be saved after reprogramming the BIOS. The solution is to use attached BIOS images. 😁 But even after trying this, you might still encounter the same issue, right? 😁😁 Don't panic—the trick is to try pressing the ALT + F keys several times, perhaps up to 10 times, until you see the prompt 'Please select your laptop model.' After entering the model number, you will be prompted to enter the service tag. 😀😀 Good luck
                          Hi, I need bios for Dell Inspiron 15 5502
                          DN5502-WH01KR
                          Reg model: P102F
                          When I press power button, the led keyboard is on for a few second then turn off without blink or display on lcd.
                            SMDFlea commented
                            Editing a comment
                            Thread merged.
                          DN5502-WH01KR
                          Reg model: P102F
                          SN + original bios
