lenovo legion 5-15ach6h bios request
    Originally posted by Lenovochris View Post
    Some more testing Lenovo detects a different serial number to the one my computer is.
    I have display via hdmi but not on screen of laptop
    Then you have no problem with the bios. Check hardware.
    Become a Badcaps supporter
    Thanks to all supporters.
      Yes seems that way, thanks for your help.
        Bios request
        15ach6h
        PF47JGN6
        Currently running GKCN65WW
        Takes ages to fire up, power light cycles before booting in to windows with fan and CPU on full.
        Then shuts off after 30secs.
        Doesn't display image on discrete, but did on integrated.
        Will get a bios dump later thanks
          Bios request
          15ach6h
          PF47JGN6
          dump added Thanks
            dump added Thanks
            Does the bios look ok? Thanks
              No longer does anything apart from fans spin for a second after initial power button press
                Legion 5 Pro-16ACH6H Laptop (Lenovo) - Type 82JQ
                sn PF3BKNSQ
                need help with the bios
                  sn PF3BKNSQ
                  You have everything you need at post 5 .
                    sn PF3BKNSQ
                    hi try new file
                      sn PF3BKNSQ
                        please send bios for Legion 5 15ACH6H MTM: 82JU003FCK
                        S/N: PF3BFL21
                        Thank you
                        Hi can someone please help me I have a 15ach6h Lenovo Legion 5 that when you power it on the power light on the top and side turn one, the fans turn on for a second and then off again and the keyboard back lights do the same thing. The screen is completely blank and has no backlight. The laptop will switch itself off after a while as well. I believe it may need to have its bios reflashed but I am not 100% sure if this is the issue or if something else is. Any help will be greatly appreciated.
                        Brand: LENOVO
                        Product ID/MTM/: 82JU006YUK
                        Model name: Legion 5 15ACH6H
                        Main Board: HY660 HY561 HY572 HY56C HY57K NM-D562 Rev:2.0(2021-01-25)
                        CPU: AMD Ryzen 7-5800H(100-000000295)
                        GPU : RTX3060 6GB (GN20-E3-A1)
                        Screen: 15.6" (1920 x 1080, Full HD, IPS 120Hz)
                        Bios dump files attached below.
                        Please see attached for serial and other details
                          Hello everyone , i have lenovo legion 5 5-15ACH6H Laptop (Lenovo) - Type 82JU
                          serial number is PF2YJSKV MTM : 82JU002XUK MO: PF9XB1523009
                          Already tryed use everything what is in post 5 but no success
                          My problem is black screen after power up and nothing more , backlight lights up and off , then sometimes bootloop , with nothing on screen , side power led blinking.
                          Before i flash bios from post 5 i have different issue :screen black then fans spin fast and power off.
                          Have few questions
                          what i should choice in neo programmer w25q128fw OR w25q128fw_1.8W ??
                          Then Should i erase chip befor flash new bios??
                          and at last , can i have working bios for this laptop ??
                          I have lack of budget for specialist repair , trying fix myself with
                          JZK Routing USB Programmer CH341A
                          Please help and im sorry if write something wrong
                            Please Type and post the laptop serial number, don`t post pictures. Read the rules https://www.badcaps.net/forum/troubl...before-posting
                              Brand: LENOVO
                              Serial Number: PF2ZRV8A
                                hi try new file flash 16 mb
                                  Have few questions
                                  One more info . what if i erased wrong chip ???
                                      Thank you. I tried it but unfortunately it's made no difference. Unsure on where to go with it now
                                        Hello guys! Looking for some help with my Bios.
                                        Lenovo Legion 5-15ACH6H - Type 82JU
                                        Serial Number - PF2YPSBD
                                        MB ID: NM-D562 rev 2.0
                                        When I turn the laptop on, the Screen in Black, only the backlight Keyboard lights up and fan spins, processor warm. I think the BIOS may be corrupted.
                                        Many Thanks
