DELL XPS 9360 BIOS Corrupted
    I have a Dell XPS 13 9360 Notebook (CAZ70 LS-F051P REV 1.0(A00), symptoms are it turns on, LED's are lighting up, there is CPU FAN spin, CPU is heating up, but no POST, no display.
    Voltage is present on all rails, there are no shorts, so I think it is a BIOS issue. I have attached my BIOS dump. Could someone please send me a fixed/clean version with ME info transferred?
    I thank you very much in advance.
    Cheers,
    sect-sin
    Re: DELL XPS 9360 BIOS Corrupted
    Dell XPS 13 9360
    Become a Badcaps supporter
    Thanks to all supporters.
      Originally posted by hoaca388 View Post
      Dell XPS 13 9360
      Hi hoaca,
      Thank you for the BIOS files. I used the non-vpro version, as I think the notebook is a non-vpro version (though I am not 100% sure).
      It still does not POST, but the symptoms have clearly changed. Now there is a 2 amber, 5 white error blink code, which means wrong memory installed, then there is a short fan spin, and then shutdown.
      This is strange, as the memory is soldered on the board.
      1) Should I try the vpro version?
      2) Is there something wrong with the BIOS file you gave me?
      3) Or is the soldered memory faulty?
      What do you think?
      Cheers,
      sect-sin
        No problem with bios files, if both don't post clearly the error is not due to bios.
