Guys im in need of schematic or BV for HP FPW50 LA-H323P
HP FPW50 LA-H323P have anybody schematic or BV?
Re: HP FPW50 LA-H323P have anybody schematic or BV?
A 15s-du1016TU (with a LA-H323P motherboard) came in dead with water damage. A number of areas were affected, mainly a number of QFN's. Board worked ok after rework. I took the opportunity to grab some voltage references off it for future reference as there's no schematic currently available.
Some other stuff:
PU301 SY8286BRAC +3.3V (AWV)
PU302 SY8270CTMC +5V (BTX)
PU1001 SY8286RAC +1.08V (BAA)
PUB1 BQ24725A (BQ25A Battery IC)
PUM1 G5616B 1.2V (DDR4 Buck converter)
PQA1, PQB1, PQM1 EMB09A03HP FET
EC is ENE9022Q and programmable.
Originally posted by reformatt View PostSVOD programmer keyboard pinout for the ENE9022Q
Originally posted by reformatt View PostA 15s-du1016TU (with a LA-H323P motherboard) came in dead with water damage. A number of areas were affected, mainly a number of QFN's. Board worked ok after rework. I took the opportunity to grab some voltage references off it for future reference as there's no schematic currently available.
Some other stuff:
History, this board was working fine until I opened it up to upgrade the NVME. I disconnected the battery and when I put it back together I get the dreaded 5 long flashes 3 short on the caplock.
All the other rails are present and correct. I can't determine what triggers that PQA1 FET and the mosfets in that circuit to power the CPU. The SIO by chance????
Some other stuff:
Originally posted by wilmer javier View Posthello, good afternoon, I received a plate just like this one, and I need to know the value of the plm2, which in my case is blown up or burned, that's your answer, thanks
