looking for HP 450 G1 boardview link if it was posted on the forum please
    hi today i was trying to ripair hp probook 450 g1 its problem is when it is plag in the charger conecter the LED blink continously when i turnon it wont turnon their is no 3.3v or 5v but their is 19v so if any one solve this problem pls help or if u have the schmatic
    thanks
    Re: [help] hp probook 450 G1
    HP PROBOOK_450 G1 wistron
      Start by checking if middle pin connector is shorted to ground.
      If so change D4201
        thanks
        If the bios is corrupted it could do this. I had a problem with an Acer that did this and after I took out the battery, disconnected the adapter, pressed the power button and held it for 30 sec. and took out the bios battery it was alright when I put it back together. I believe when the power saver mode turns on sometimes it can can cause the unit to go into some loop fault when there is none. Perhaps if the Bios is re-flashed it would correct this problem?
          Rampage mb 12241-1 48.4yw03.011 schematics
          Does anyone have schematics of HP Probook 450 g1?please.
            Re: Rampage mb 12241-1 48.4yw03.011 schematics
            https://www.badcaps.net/forum/attach...5&d=1505291915
              thanks
                  Re: looking for HP 450 G1 boardview link if it was posted on the forum please
                  What is the motherboard part number ?
                    Rampage_MB 12241-1 48.4YW04.011
                    AND
                    Rampage_MB 12241-1 48.4YW05.011
                      The boardview doesn`t seem to be available sadly, only the schematic.
                        thanks very much
                          Hello, I have the same symptoms and in my case it was a blown capacitor C4916. (I hope as I didn't power the board up yet after removing it)
                          The question is is it a 22uF 25V one?
                          I have many donor boards and can't find this cap on any of them so far. Do I read it correctly?
                          Thank you
                            22mkF 25v
                            The laptop will work without this capacitor).
                              Originally posted by AL._.EX View Post
                              22mkF 25v
                              as you said, works!
                              thanks
                                Thank you
                                Could you please show me where that C4916 capacitor is on the motherboard? I've searched a lot and can't find it...
                                  I've just repaired an HP 470 G1 which also died due to C4916 but also suffered an exploded first mosfet which welded the pads. I had to rip the pads off and bridge plus line from a nearby test point with my NAKED EYE.
