Schematic for hp 15-s da0p5dmb8c0 Quanta 0P5
    Re: Schematic for hp 15-s da0p5dmb8c0 Quanta 0P5
    Originally posted by oddbondboris View Post
    boardview and schematic attached
    open with edge
      Thank you
          I need a schematic diagram Hp model: 15-da0040ni motherboard epk50 la-g073p or equivalent
            Off topic,this thread is for the Quanta 0P5 .Use the forum search !
              THANKS
                Click image for larger version  Name:	image.png Views:	0 Size:	8.38 MB ID:	3299856
                I need to watch images ın HD to see the ic switch regulator 3v and 5v
                  Could someone please help me? Or could you tell me the code for the integrated circuit here?
                      In laptop (da0p5nmb8e0 rev e) and info on the three MOSFET near cpu marked AT00 3NCR? Two giving 0.8v and one giving mV. And laptop keeps restarting.
                        AT00 AOZ5016QI https://www.badcaps.net/forum/troubl...41#post1538441
                          Re: Schematic HP 15-ef2126wm DA0P5JMB6D0 REV D Model 0P5J
                          any idea what the chip is?
                            I need help with the USB daughterboard, one port works, the other does not. A small part was damaged and replacing it does the trick (I guess) but cannot identify it, the PDF schematic has ony a little part of the daughterboard components listed and not in the boardbiew one at all.
                            Click image for larger version  Name:	IMG_20241009_184251.jpg Views:	0 Size:	1.62 MB ID:	3480479
                              thank you very much
                                SY8286C
                                  thank you
