As per the title, I've got an ATX PSU that's only giving 5v standby. I've checked the mosfets and diodes, and they all seem OK, so my next suspects are the output monitor chip (DM311) and the PWM controller (UC3845A). I'm too much of a coward to try to test these live (the PWM controller is buried between the two heat sinks), so now I just start swapping things out. I don't have any of either to hand, but what I do have is some UC3843AN, which are the same family as the latter, but a slight variant.
According to the datasheet, the first digit relates to operating temp. They're both 3, which is 0°C to 70°C, rather than 1 or 2 which are for more extreme environments.
The last digit describes the operating voltage, 3 and 5 are "TURNON AT 8.4 V, TURNOFF AT 7.6 V, SUITABLE FOR DC-DC APPLICATIONS" (as opposed to 2 or 4 which work at 16 and 10 volts), so again no problem there.
The last letter(s) just relate to design improvements over the years. They all seem to be compatible, but the later ones draw a little less current.
So the difference between the 3 and the 5 versions is related to the duty cycle. The 3843 can run from 0% to 100% duty cycle. The 3485, however has an internal flip-flop that pulls every second pulse low, so it can only drive the mosfet up to 50% (and presumably at half the frequency of the oscillator). The switching mosfets are a couple of 20N60C3, and the output diodes S30D45C and S30C100C which seem to be bog standard components in PSUs.
I can't see why it wouldn't work, but I'm just curious if anyone here has any thoughts on it.
