Here are some pictures of a Diy power conditioner i made, chassis is lined with green quartz (very hard and uniform) painted black. "chokes" if you can call them that (both measured 0.03ohm with my fluke), heavy gauge copper cables through 4 ferrite rings filled with quartz then held together by led weights. The little chokes you see in the pictures come from 2 Pc power supplies
Doing 1 phase each, then the biggest Wima caps i could find.
The little circuit is from a Usa made power strip with basic filtering, but most importantly protects from lightning and shock from the chassis (when the ground is done)
I might need a couple resistors after the big ones because of their capacitance wich could be pretty big because of the massive cables.
Im no Engineer so any input would be appreciated.
