Do main caps go on a GX280 SFF PS
  • JOHNBOY
    • May 2010
    • 78
    I changed 90% of the caps and it still just makes a growling sound but doesn't start. The main caps look really cheap, I'm wondering if anyone knows if they are a known problem on these.
    This is the one with the thinner fan, I always have good success with the other variation which is a lite on, but these ones always just growl for a second after a recap.
  • seanc
    • Nov 2008
    • 1319
    Re: Do main caps go on a GX280 SFF PS
    'Growling'.
    Do we have SFF or USFF with external power brick here?
    • JOHNBOY
      • May 2010
      • 78
      There is no USFF in a GX280. Not in north america anyway. The separate power brick is a totally different model. I believe gx620 or something.
      The power supply just makes a buzz / growl for one second when pressing the power button. I have 5vsb but that is it.
      • seanc
        • Nov 2008
        • 1319
        Sorry, I read SX280!
        Have you checked the mains capacitor? Next I would look at transformers.
        • JOHNBOY
          • May 2010
          • 78
          I pulled the mains and both were reading 289 and 290uf on a basic capacitor tester. It should be 330uf so it makes me think they're good.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            hmm... do you have any primary caps floating around that you could sub in? what brand are the existing ones anyway?
            sigpic
            (Insert witty quote here)
            • JOHNBOY
              • May 2010
              • 78
              No I don't have spares for those big ones. It is a no name brand. black sleeve and the letter M inside a TV box (M) CE . I bought this brand before in a smaller size and you guys slammed me for it.
              I just changed the last 1000uf 10v and still the same 1 second of buzz when I plug it in.
              • Scenic
                o.O
                • Sep 2007
                • 2642
                M inside a box [M] is Panasonic/Matsushita
                http://rocky.digikey.com/weblib/Pana...ES%2025,25.jpg
                • JOHNBOY
                  • May 2010
                  • 78
                  Would it be a disaster if I put in a 470uf for a couple of seconds to see if it turns on.
                  • yyonline
                    • Jul 2009
                    • 692
                    I doubt anybody here would fault you for buying Panasonic capacitors, which are a very reliable brand. This assumes, of course, that they were real Panasonic (not fakes), and that they were the correct type of capacitor for the application. It's possible to have a perfectly reliable capacitor that is just ill-suited for a particular application.
                    That said, if the originals are Panasonic, they are unlikely to fail. That said, SFF computers do like to cook even the reliable brands.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Panasonic makes a variety of series. Each series has a specific use. Panasonic FM, FR, and FC are low ESR caps. [M] CE is a general purpose cap (i.e. not low ESR).
                      The same goes for other manufacturers. Rubycon makes low ESR and general purpose caps.
                      Last edited by retiredcaps; 02-04-2011, 01:25 PM. Reason: edit: Noticed typo thanks to yyonline in post #13
                      --- begin sig file ---
                      --- end sig file ---
                      • yyonline
                        • Jul 2009
                        • 692
                        Originally posted by retiredcaps
                        M is a general purpose cap (i.e. not low ESR).
                        As to not confuse the new people... It sounds like the mains cap in question here is Panasonic CE series.
                        [M] in a rounded box is Panasonic's logo. This appears on all Panasonic capacitors, regardless of the series.
                        M not in a box on a Panasonic capacitor would be the series.
                        • JOHNBOY
                          • May 2010
                          • 78
                          I switched over a set of good 470uf caps and got the same buzzing and growling for one second. I don't think its a cap issue, these wan wien power supplies suck. I tried to jump start it a few times and eventually the 5VSB went away, now I think I have a blown fuse.
                          • Dani_2024
                            by Dani_2024
                            10-28-2024, 05:06 PM
                          • eryjus
                            by eryjus
                            05-10-2023, 11:21 AM
                          • cheeky2
                            by cheeky2
                            05-25-2024, 03:27 AM
                          • Paxman_Swede
                            by Paxman_Swede
                            Hello!
                            01-14-2025, 09:51 AM
                          • captain150
                            by captain150
                            03-16-2025, 07:34 PM
