Super unreliable tape drive PSU
  • pentium
    • Mar 2006
    • 2778
    Ever since I got my desktop Cipher 9-track tape drive it's never worked. The thong would normally just sit emitting a low buzz and eventually the front panel would light up but diagnostics would fail. If you remove the PSU out of the unit you can hear the fan runs faster and the buzz gets a bit less angry but if you leave even the power supply alone for long periods and try to use it again, it will be a dead brick, only emitting the odd volt or two and buzzing from the primary transformer when you flip the switch. It will also of course spring to life if you leave it on for a while.
    Here is the unit itself.
    The only physical damage I found was browning fo the PCB around the joints on four resistors and diodes. The components by the way checked out as OK when removed and checked. All but two caps (and the two primaries) were in stock at the local electronics shop so it's also been mostly recapped too.
    I'm out of ideas on what else might be at fault and I can't find a schematic or even a pinout. I have been wanting to get this drive working for almost a full year now.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Super unreliable tape drive PSU
    When you say "buzzing from the primary transformer when you flip the switch," I assume you mean the SMPS transformer on the PWM board.
    What kind of noise(s) does the boost inductor make?
    I see there are three wires from the boosted supply to the PWM board. If there were only two, I'd tell you to check the boosted supply for the usual 360 - 420 V DC. But those three wires...
    Are those two big caps connected in series? Of the three wires (red, blue, yellow), does one go to the top of the series connected group, one to the bottom, and the last to the center point of the two caps?
    And is there any surface mount stuff on the back of the board?
    When does that relay click? Right when you hit the switch or only after it suddenly comes up?
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • b700029
      Banned
      • Sep 2010
      • 640
      It looks like a pretty common UC3844-based design with a few rails (and an odd +38V one.) The primary including switchers is on the lower half while the main transformer and secondary is on the upper half. From the pictures it looks like the 3 thick wires go to the primary winding on the transformer in the upper half.
      • pentium
        • Mar 2006
        • 2778
        The one closest to the mains input with the yellow tape wrap one coils.
        It gives off a low and faint hum.
        One of the two large transformers on the other board (you called that the PWM board, right?) however will give off a rather angry buzz when the PSU is connected to the tape drive and under load.
        The yellow wire on the three wire harness connecting the the two halves is also the only one giving a voltage. Only 23.6v.There are no surface mount parts on the flipside. Those two major caps are mos likely the filter caps.
        The relay never clicks when the main switch is flipped. At least, I never hear it.
        It does however give a faint click in and out a few seconds AFTER you switch the PSU off.
        Find Nedry!
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          If you mean LF2, that may just be a common mode choke. The AC line should pass right through it. Trace it if you want.
          T1 is the main transformer, L3 is the output inductor.
          I made a mistake- I ASSumed there was a PFC booster. Clearly, there is not. Sorry for the confusion. Looks like that first board is the AC input/filtering, PWM/forward converter commutation, and control. Second board is TX/output inductor, secondary rectifiers, filter caps/chokes, maybe some 78xx regulators, dummy loads, and part of the feedback.
          23.6V to where? Where did you connect your other test lead? That looks like the primary of the transformer- high freq. AC that your meter may not read correctly. Look around/trace near those MOSFETs- you should be able to figure out how/where the actual PWM gets its raw DC. If it is in fact a single-forward converter, the three leads are:
          End 1 of primary
          End 2 of primary
          End 2 of "flux reset" coil
          The other end of the "reset" coil will be shared with one of the primary leads.
          If there's no "reset" coil, the third lead may just be an electrostatic shield in the transformer.
          Check those two big thermistors for continuity. Check for equal voltages across the two big caps- you'll have to run it with the boards out. If the rectifier is good, each big cap will have the same voltage across it. The voltage across the two in series will be the sum of both.
          Many years ago, I got what must've been an ancient external QIC or Ditto drive. It must've been junked because it no longer had power. I "played" with its power supply, an open frame Eltek, 5/12V, 4A each. I never did get it to work, but noticed that only one of the big electrolytics ever charged up. At the time, it stumpted me, since I thought it should do something with one cap charging. But now I know that its LVCO was probably locking out. After unplugging, one cap would give a satisfying bang when shorted. The other one, zip. If I still had it, the first thing I'd try would be a new rectifier.
          There appears to be a seperate small power supply, too. Are you sure the three MOSFETs on the board with the big caps are OK?
          EOL it...
          • pentium
            • Mar 2006
            • 2778
            To chassis ground.
            Which ones? There's a few.
            So just poke a DMM at it and flip the scale to 200v? Should I do the test while the board has power or just after power is removed?
            Find Nedry!
            • pentium
              • Mar 2006
              • 2778
              BuMP.
              Find Nedry!
              • kaboom
                "Oh, Grouchy!"
                • Jan 2011
                • 2507
                RT1 & RT2, they are black with nylon "bases."
                With the power on, across each cap on the 200V scale. You'll have to remove and support the board(s) somehow. Try some of those polyethylene/polypropylene cutting boards. Even tupperware will do!
                Since you'll be floating your meter, either use a good one or do the following:
                Solder short heavy wires to the cap terminals; use alligator clips to connect test leads to wires from the caps; keep hands off meter (if it's an 830.)
                With 120V going in, you should have 150-170V across each cap, 300-340 across both in series.
                EOL it...
                • pentium
                  • Mar 2006
                  • 2778
                  Sorry for the wait.
                  RT1 and RT2 both read about 6 ohms in circuit.
                  The caps on the other hand....give me 79.8v each and 159v in series. Something is very, very wrong.
                  Find Nedry!
                  • kaboom
                    "Oh, Grouchy!"
                    • Jan 2011
                    • 2507
                    Sounds like you have only rectification taking place. If it were doubling, you'd have ~320/~160 (series/singly, respectively) across those caps.
                    On that relay, can you tell if there are a set of contacts that close, between the midpoint of the two caps and one side of the line?
                    Look carefully at the "120/240" switch in the diagram. It's (supposed to be ) open on 240 and closed for 120. If that relay takes the place of the 120/240 switch on your supply, closing when a comparator drives a transistor supplying the relay coil, and it never closes, your bus voltage will be one-half of 'normal.'
                    At this point, I don't think the bridge rectifier is suspect. Both caps charge, and "equally." Equally in quotes since you don't really have a load on it, but we can ASSume the bridge is good- one open diode and one of the caps wouldn't charge, but one shorted diode would blow the fuse (AC into an electro.)
                    If I had it here, I'd trace those contacts from the relay out, and if no 120/240 switch, hard-wire it for 'doubler' action. It would then, obviously, be set for 120 only.
                    -Paul
                    EOL it...
                    • pentium
                      • Mar 2006
                      • 2778
                      There is no physical switch or jumper that sets the voltage range between 100-120v and 200-240v. The relay itself (RKS-5DG-48) I can't find a datasheet for but there's an indication that it's ON/OFF not EITHER/OR on the side of the unit.
                      Find Nedry!
                      • kaboom
                        "Oh, Grouchy!"
                        • Jan 2011
                        • 2507
                        The relay contacts close and set turn the rectifier up as a doubler for 120V.
                        You don't need one! There are probably four terminals/traces from the relay- two small ones for the coil and two larger ones for the point and (probably) normally open contact. Trace it carefully and I'll bet one goes to the midpoint of the two caps and the other goes to either hot or neutral, after your EMI chokes.
                        Either/or meaning 120/240V?
                        Edit- some good pix of the back of the board with the caps and relay would help me trace it out if you are stuck.
                        EOL it...
                        • pentium
                          • Mar 2006
                          • 2778
                          As in either the relay contacts are connecting A to B or they are connecting A to C.
                          Anyways, pictures are helpful.
                          Find Nedry!
                          • kaboom
                            "Oh, Grouchy!"
                            • Jan 2011
                            • 2507
                            I felt like I was missing something. All along, R19 (lower left corner) has blown and R43/R44, maybe R45, look like they were running hot. Check that the 5W 3.6K wirewound is good, and check Q5 for shorts.
                            Also check that big red R5 (upper left corner) for resistance. Check any components above hotspots on the back of the board.
                            I know that sounds a bit vague, but if you took some macro pix of the areas of interest, we could see the color codes better. R19 is (was) a yellow-purple-something- a 47x.
                            Check any of those diodes near that opamp. Is that an LM356 or 358? Just use continuity check- if the diodes have shorted, they're shorted.
                            If it's just a single opamp (LM356), it may sense the voltage on the caps and drive a small TO-92 transistor to pull that relay in. IOW, if that opamp ckt does not work properly due to bad parts, the relay will never close and fail to set the recto up as a doubler. Hence your low bus voltage. First determine if it's a 356 or 358, then get its pinout/datasheet and make sure none of the inputs or outputs are 'stuck' at its supply voltage. If they are, the opamp is bad and also needs to be replaced.
                            In the attached image, check the following:
                            If both red points have continuity to each other
                            and
                            The yellow point to either of the blue ones also has continuity, then the relay takes place of the 120/240 switch; ultimately pulled in by way of the opamp/comparator.
                            In your OP, you said that any suspect parts checked ok and were put back. Just be aware of any carbon residue under those hot resistors- any leakage will upset the bias on, and change the setpoint of, that comparator. And if the element is exposed on R19 and touching nearby traces, components, or leads, then fix that, before banging your head in frustration.
                            EOL it...
                            • pentium
                              • Mar 2006
                              • 2778
                              R19 has already been pulled from circuit and tested and still reads good. R43 and R44 read 74.4 and 75.2k each. Their bands are red, brown, yellow, black, black, gold (or brown. The light I'm working in is awful). The 5W is good. Q5 is one-way from S to D and S to G. R5 and R4 also read their proper values. That is also an LM358N. R19 was yellow, purple (or brown), (something), black (or black-ish). It currently reads 4.73k. All the diodes I poke at seem to be working one way so they should be fine. Q1 was also tested and seemed okay.
                              Find Nedry!
                              • pentium
                                • Mar 2006
                                • 2778
                                Going to BuMP this because two years later I have only just returned to it.
                                So I traced down the bridge rectifier which is a KBU8G and that I can see it's properly converting 117v AC to 117v DC. I can see that either DC polarity passes through a CL-40 current limiting resistor before going to each of the two primaries. The other sides of the capacitors travel to P2 and to the secondary side of the PSU as well as to R4 and R5. It also travels to the RKS-5DG relay which is normally open, otherwise it would travel to one side of the AC input of the KBU8G. It seems to be powered by something up in the region by U2. (see previous attachments)
                                In other words I still can't say why We're only seeing almost 80v on the primaries, assuming that's not what we should be seeing at all.
                                I have not yet contacted Tectrol regarding schematics.
                                Find Nedry!
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  I'm not entirely sure what I have done but it now fires up regardless of it being attached to the drive or not. After that the drive now immediately reports logic errors. Poking at the rails finds that +5.1, -12 and +12 are within tolerances by about .1 or .2V but +38 reads +33.5 and +5 reads +4.5.
                                  There's evidence it was recapped before but a few caps (50v 1500uf, 40v 220uf, 50v 47uf and two 25v 4.7uf's) were not disturbed. Those are some oddball values I can't locally find for cheap either.
                                  Find Nedry!
                                  • pentium
                                    • Mar 2006
                                    • 2778
                                    Also, to add to the symptoms and answer a previous question, the PSU is a true autoranging device so you don't need to change anything when powering it from 240v. That being said, while the front power button does not work on 120v line power (pressing it does nothing), it will work under 240 line power. (pressing it turns the tape drive AND the PSU on or off)
                                    Find Nedry!
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      What voltage ratings are the main caps? If they are 200V, then they must be in series, so the PSU can work on higher mains voltages. Then, with 120VAC input, you'd see about 80V on each capacitor
                                      Muh-soggy-knee
                                      • pentium
                                        • Mar 2006
                                        • 2778
                                        Yeah, they're both rated for 200v.
                                        So if you say 80v each then we are in the neighborhood.
                                        Find Nedry!
                                        • Destroyer-Br
                                          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                          by Destroyer-Br
                                          I'm working on an Acer Nitro 5 unit with the following specs:
                                          • Motherboard: LA-J871P Rev: 1B
                                          • Model: Acer AN515-55-59MT
                                          • S/N: NHQ7JAL00403906A973400
                                          • SNID: 03902728734
                                          Initial Issue
                                          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                          04-17-2025, 08:18 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • RetroComputingGrotto
                                          IBM LTO 7 Tape Drive - Dust Sensors??
                                          by RetroComputingGrotto
                                          I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                                          I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                                          09-19-2024, 01:54 AM
                                        • triplefour
                                          LG 75UN8570AUD panel issue fixed with tape.
                                          by triplefour
                                          I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                                          add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                                          07-17-2023, 10:22 PM
                                        • jshhh
                                          Help repairing Yamaha RM1X synthesizer/groovebox - PCB trace for capacitor has been pulled off
                                          by jshhh
                                          Hi guys,
                                          I've been trying to restore this Yamaha RM1X groove-box I bought, and the first thing on my agenda was to replace a bad capacitor that was making it so that the screen was super dim. As I'm a complete novice I went and accidentally pulled off one of the trace pads for the SMD capacitor as I was removing it, pulling up some of the green PCB with it. I've been trying to repair it by gluing down copper tape from where it began to pull off and solder the capacitor on after...atm I've just been attempting to do the same kind of thing on rubbish PCBs I got at a recycling place,...
                                          03-26-2025, 07:05 PM
