How often do you guys do a preventative recap?
  • c_hegge
    • Sep 2009
    • 5219
    Re: How often do you guys do a preventative recap?
    IMO, if it isn't worth recapping with good Japanese caps, then it isn't worth hanging on to.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      I'm sure the Jamicon would have lasted longer but since they were all on the 12V filtering, I figured those were the best ones to replace if it's going to be seeing a lot of use.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Well, as far as ATX power supplies - I don't always use them to power computers. In some cases, output ripple isn't important at all and as long as the PSU is working, that's all I care about. Problem is, if the output caps are bad, the PSU may not regulate/function properly. So in those cases, sticking any crappy (but not yet failed) caps in it is already a big improvement.
        • c_hegge
          • Sep 2009
          • 5219
          Well, bench PSUs are a different story, but I was referring more specifically to stuff which would be used in a PC
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Since my Japanese caps are too big and it's just an L&C, do you think it's even worth replacing the YC caps with slightly used Teapo and OST caps? They shouldn't be stressed heavily, they're 2200uf 10V. I want to recap the entire thing, and I replaced that 4A rectifier with a 6A one
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              #26
              Make sure that the caps are not near a heat source like a resistor, that the fan is cooling effectively the psu and of course avoid to put non japanese caps on the 5vsb line. Almost forgot, NEVER use 85Celsious caps.
              You could also search the datasheets of the caps to check if they are low esr or general purpose. Don't use general purpose even if they are 105C rated.
              • mariushm
                • May 2011
                • 3799
                #27
                I don't see any point in replacing the 4A rectifier, you won't draw more than 3A or so on that... and I doubt
                In old design power supplies you will have resistors near each voltage rail, which load them with about 0.1-1 watts usually.
                Here they are on your psu
                Those designs need a minimum load to regulate and prevent oscillations and those resistors will get warm. You can bend them to be a bit further away but there's not much room there to put them away from the caps.
                Maybe if you move the cables around so that the resistor core is further away... but they will still be covered by the cables so they won't be cooled by the fan.
                You could just solder some cable in the holes where the resistors are soldered, put the cables through some heatshrink tube, solder the resistor to the cables and then heat up the heatshrink over the resistors to insulate them and glue the resistors to the metal case .. now they should be far away from the capacitors.
                The inductors may also be quite warm but there's not much you can do about it.
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  #28
                  I didn't notice these filter coils getting warm until now. The toroid ones can get very hot though.
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Yeah I try to bend them farther away. So, you think the YC's can handle the heat?
                    • jsmoke
                      • Sep 2012
                      • 23
                      never done a preventative recap, although I am a big fan of "If it ain't broke, fix it!".
                      • lti
                        • May 2011
                        • 2555
                        I agree, especially if it is new or is still under warranty. I don't see why anyone would recap a new device before they even test it to see if it works.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          #32
                          I agree.
                          Considering most computers don't draw more than 200W under max load, there probably won't be more than 2A going through that bridge rectifier.
                          They do indeed, but I have been changing them on many of my power supplies. In fact, the edited pic you posted is of my 250W Deer PSU. In that PSU, I actually changed the minimum load resistors with slightly higher resistance ones because the old ones were producing so much heat that they were carbonizing the output wires.
                          This is what that PSU had before:
                          3.3V rail: 10 Ohm 2 Watt (~1.1 Watts dissipation)
                          5V rail: 47 Ohm 1 Watt (~0.53 Watts dissipation)
                          12V rail: 100 Ohm 2 Watt (1.44 Watts dissipation!!!)
                          Those resistors got so hot that even the PCB started to darken a bit. So this is what I changed them with:
                          3.3V rail: 47 Ohm 1 Watt (moved from 3.3V rail)
                          5V rail: 270 Ohm 1/2 Watt (IIRC) (notice how high I went with this one - this is because the computer this PSU is powering is a Pentium 3 which puts a heavier load on the 5V rail than anything else)
                          12V rail: 2x 1 KOhm 1/2 Watt in parallel for 500 Ohm combined
                          Since this PSU is designed to get feedback mostly from the 5V rail and the 5V rail is always well-loaded with the CPU, the regulation was actually really good.
                          So all in all, you can remove/replace those resistors but you have to be careful that the PSU is properly loaded if you want good regulation.
                            ASUS P5GC-MX motherboard recap
                            by momaka
                            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                            So here is what the motherboard looked like with its original caps:
                            CPU VRM area up close…...
                            01-27-2021, 11:59 PM
                            no-name Radeon 9600 XT recap and cooler
                            by momaka
                            I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                            This one was actually suggested to me by ChaosLegionnaire....
                            11-06-2020, 07:54 PM
                          • Foetuss
                            Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                            by Foetuss
                            Hi all
                            Hope this is in the correct place.
                            I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                            Could use some double checking to see if I'm not doing something stupid .
                            Pictures of the boards are attached.
                            What I will be replacing with what : (planned)
                            Soltek Golden ::
                            4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                            6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                            01-18-2025, 11:44 AM
                          • zmeutul
                            hi guys i need bios for 6-77-NP50PNJY-D02B-3C
                            by zmeutul
                            hey guys I need a bios for 6-77-NP50PNJY-D02B-3C.With the current one, the laptop does not start. I am also attaching the original bios. Thank you!...
                            09-26-2024, 01:55 PM
                          • goodpsusearch
                            Got 4 LG L222WS 22" for free - psu recap
                            by goodpsusearch
                            Got 4 CCFL 16/10 monitors for free.
                            The resolution is almost Full HD (1680x1050)
                            VGA Input only is a bummer though.
                            Uses cheap TN panel with terrible viewing angles.
                            Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
                            All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
                            01-15-2022, 05:36 PM
