I am trying to repair a Yamaha DXR10 powered amplifier but finding it difficult because I have a smoking resistor which starts to burn as soon as I switch power on. (So I have it turn it off straight away.) The fuses don't blow and I connect a dim bulb which goes dim so no straight short to find. I have attached a marked up circuit diagram and I am looking for help in identifying the best place to look for what's causing the excessive power draw. Needless to say the amp isn't working. The mosfet circled in red was the start of my problem when it exploded. I replaced it and the resistor network also circled in red. The circuit in question and the components I am suspicious of are circled in yellow and numbered in blue.
No 1 marks the resistor that smokes.
No 2 marks a mosfet that seems to test OK.
No 3 marks a resistor that tests OK.
No 4 shows where the circuit joins the PWM.
No 5 ids the last capacitor in the circuit before it goes to ground.
No 6 shows where the mains AC seems to provide a GND for the circuit. (Don't understand why the mains AC joins the rectified AC coming from the bridge rectifier at No 8.)
No 7 circles a structure I just don't understand.
If anybody can advise where I should start to look for the source of excess current I will be grateful.
Best wishes
Brian
Best wishes
Brian
