Corsair RM 750 blown schottky diode near ES1DF
  • iyas132
    • Aug 2019
    • indonesia
    Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
    Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
    My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
    Can anyone help me identify the component marked "SF" on the picture. Thanks!
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    B0540W-7-F, 40V 500mA Schottky
    • iyas132
      • Aug 2019
      • indonesia
      thank you for your help
      • lcdcaps1
        Usb rechargeable hair clippers blown tp4056 and zener diode
        by lcdcaps1
        Hi
        all
        I have a usb rechargeable hair trimmers that should work plugged in and charge
        it stopped working no led norhing
        I've opened it up and see the tp4056 chip has blown
        There is a zener diode that I tested and get a near short ohms reading no matter which way my leads are
        I don't know what to replace this with
        Please help
        thanks so much...
        03-07-2024, 09:56 PM
      • mikay786
        Toshiba VCR / DVD blown diode?
        by mikay786
        I've got a shorted SB390 diode which was in parallel with UF5408 diode.
        d1031 = uf5408
        d1035 = sb390
        service manual pages 1-14-25 & 1-14-26
        Ive found a equivalent for the SB390 in the SB3H90
        what i wanted to know is it likely that the UF5408 has already been replaced?
        As in originally both diodes would have been SB390s
        So if i were to replace the pair could i replace both with SB3H90?...
        06-07-2023, 04:52 PM
      • nubie
        Chi Mei M236H1-L01 C2 Blown Diode Acer 24"
        by nubie
        Due to some moisture the VGHP/HVS1 line shorted and this diode D8 blew. The picture is there. It just fades in after some minutes and is quite solarized. Updates again take minutes.
        Any idea what Dioide to use? Thx.
        Many thanks...
        01-26-2024, 11:17 AM
      • hobostove
        Corsair RM1000e - Help identify 5VSB Zener diode
        by hobostove
        Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
        Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
        There's a 22ohm resistor that's melted and open, but it still has the bands.
        The other part is a zener diode and it's top went to jesus, so I can't read the marking.
        It looks like the diode connects the source and drain of a TNY284...
        03-27-2025, 02:25 PM
      • asr
        Finding replacement diode iPad Pro 3rd gen A1701
        by asr
        Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
        Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
        07-09-2024, 06:24 PM
