Making transformers
  • Rulycat
    • Apr 2010
    • 724
    • United Kingdom
    Making transformers
    During lockdown I decided to do more research on power supply theory, take this image for example:
    http://www.pavouk.org/hw/en_atxps.html
    This is the DTK 200w schematic that seems common on the web... I would like to build a clone of an old design such as this to understand better how it works (we learn by doing, after all) I don't fully understand why everything is the way it is, but that would be the fun of building a copy... the only thing I can't get my head around is, how do forum users on here go about building a transformer? Parts are easy to get but a transformer I would presumably have to wind myself?
    Side questions:
    Safety-wise, this is fucking with 230V AC, so I was planning safety glasses, and presumably plugging the thing into an RCD plug in the wall - what do you use to minimize the risk of high voltage?
    Re: Making transformers
    Not simple: Examples
    https://talema.com/smps-transformer-design
    https://www.wcmagnetics.com/resources/
    https://circuitdigest.com/tutorial/h...upply-circuits
    https://cdn.badcaps-static.com/pdfs/...49659ecc97.pdf
    Or learn about SMPS design: Example
    https://www.smps.us/smpsdesign.html
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      As a coincidence I just watched these two videos, they have useful theory:
      Is it easy to create your own Transformer? Everything you need to know about Transformers! || EB#42
      Can you 3D print a Transformer? (Experiment) || How to make a mains Transformer!
      • Rulycat
        • Apr 2010
        • 724
        • United Kingdom
        Looks good, I was struggling with where to get materials for a transformer as well like the core... as I don't have any PSUs lying around to cannibalise...
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          I've made a bunch of them years ago, they're still chugging just fine. I have a spreadsheet posted around this forum somewhere that can help you. It's called the "Mega SMPS Cheat Sheet", use that search term and you'll find it.
          It's not as hard as you may think. There are some parameters that you must take into account, these will be provided in the core datasheet. Transformer cores are standard and you'll be able to find these parameters for all of them based on their physical dimensions.
          You're going to need to know the core parameters, the operating voltage and the frequency your controller will be running at (that would be full load frequency if your controller uses variable frequency, like modern resonant mode controllers do). Plug those numbers into my magical spreadsheet, number of turns comes out as a result. Tada. Click here.
          Or if you like the hard way, the books I've based my calculations on are all mentioned in there, have a read. No safety glasses required - but if you want to be sure your creations will be electrically safe you may want to invest in a hipot tester. Or just overdo the insulation between primary and secondary, it is a critical safety aspect. More insulation will bite into your efficiency a little, but better safe than sorry.
          Side note: You'll be shocked (pun very much intended) on how much of a joke "insulation" is in some of the Chinese knockoff chargers... Any homemade transformers built with the tiniest bit of common sense will be much safer than those piles of junk.
          A working TV? How boring!
          • Rulycat
            • Apr 2010
            • 724
            • United Kingdom
            Th3_uN1Qu3, that's a fantastic document. I must have read on here years ago, but it was so long ago, it slipped my mind.
            I'm not professionally educated in this field at all so some of the information goes over my head but I do have a copy of Power Supplies A to Z (Although, a large amount of that goes over my head as well!)
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              Everything in that spreadsheet has been checked by building power supplies that actually worked (and still do!), you're welcome.
              Out of all the SMPS books I read that are mentioned in there, the easiest to understand by far is Switching Power Supply Design, 3rd edition (A. Pressman). I remember Power Supplies A to Z going over my head, too.
              • Rulycat
                • Apr 2010
                • 724
                • United Kingdom
                That's a good recommendation, I have bought a used copy online, and have downloaded a hookie copy until the doorstopper comes.
                Doing a quick scan through and it seems already more digestible than A-Z.
                Thanks for the heads up.
                • amelbye
                  is it ok to replace a dual output transformer with two single output transformers?
                  by amelbye
                  Hi, some prestory: I was repairing an amplifier - a "Phil Jones Bass". It had some bad capacitors an a faulty power switch. Easy job. However upon putting it back together I screwed up. The connector from the 15V-0V-15V from the transformer is identical to the audio ouput from the preamp board to the poweramp board. I ended up putting +-15VAC into the preamp outputs frying some traces on the circuit board along with the power transformer The transformer is shorted. It blows the fuse immediately even with no load on the secondary.
                  Now that's a challenge - luckily...
                  08-21-2020, 08:51 AM
                • mikey5791
                  Is it possible for transformer substitution?
                  by mikey5791
                  Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                  Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                  My questions are
                  1. How do i test to see if the transformer is in good working condition?
                  2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                  Hope you guys understand what i was asking. My intention is...
                  11-03-2022, 02:11 AM
                • dennis_elx33
                  3PHASE STEP-DOWN Transformer in Check
                  by dennis_elx33
                  Hello All,
                  i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                  Problem statement: Power tripped Off
                  Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                  Action Done:
                  1) Replaced the faulty parts with good spare.
                  2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                  12-02-2024, 06:52 AM
                  ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                  This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 04:40 PM
                  ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                  This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 12:00 PM
