I wonder if use of unapproved Y caps like this POS was behind the death of that Chinese person who had an after-market iPhone charger.
PeteS in CA
Re: the gutless, bloated, and fried power supply hall of shame
Get away with using unapproved caps? Maybe the agency marks are bogus. If real, the samples provided the agencies for testing had the right parts, and then cheaper unapproved parts usd in production. How much risk is there for a fly-by-night mfr?
PeteS in CA
What agencies? Nobody officialy cares! You can just stick CE on anything and sell in Europe. Well, you actually probably even do not need to do that, nobody checks even the bloody CE mark…
Not that I am calling anybody doing it! Customer is the one responsible, all the socialists can go f*ck themselvs with restrictions and regulations and controls. Does not help anyway, does it.
If it was fine prior to power off, I would suspect an issue with a startup circuit. Since the startup is only needed at.. startup... constantly running the thing will not show an issue until you power it off and try to turn it on again.
Those capacitors *look* fine, not bulging or leaking, BUT Su'scon is nothing special.
-David VanHorn
hmmm can I get a second confirming that its just glue?
That sucks as it is the only obvious thing I can see.
Does anyone have someone in New York city (I'm in Brooklyn heights) that they can recommend to check it out?
I'm comfortable pulling the board and soldering replacement capacitors but out of my league to trouble shoot a circuit.
I tested the batteries (52v at terminal and 12v on each individual battery) so don't think that's the issue.
The glue gets conductive, this was never supposed to be used in electronics so if it is already brown somewhere, clean it out. Check all fuses and power semiconductors. And preferably open your own thread for this issue…
