What do you repurpose server PSUs for?
  • japlytic
    • Oct 2005
    • 2086
    So far, I have repurposed server PSUs (all hot swap) for the following:
    • Portable multi-purpose test set with dual channel variable PSU
    • Variable frequency/voltage electrically isolated pure sinewave AC inverter
    • Low noise quad channel 0-600V DC PSU using UPS transformers with an inverter based on a trailing edge dimmer
    If you have repurposed at least one server PSU, please let me know what your application is.
    • 31214
    Re: What do you repurpose server PSUs for?
    interesting list.
    most people just use them for car diagnostics or running radio transmitters.
      master hoarder
      • May 2008
      • 12175
      Also for running car amps in a home setting with big car subwoofers.
      Old vid, but this where I first saw it:
      https://www.youtube.com/watch?v=U__WjDU92Kk
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        I have a pair of them (85A @ 12V -- 1000W) that I've stacked to form a 24V supply for an electric wheelbarrow (previously was an electric wheelchair so it goes forward/backward, left/right as well as "dumps" the load). As it never leaves the yard (and, thus, can always be within reach of a long extension cord), it's silly to put 75AHr batteries in the thing! (you usually have to modify the supplies to isolate GND from CHASSIS else you end up shorting one out when you stack them)
        I know some folks use them to rapid charge batteries in RC aircraft.
        I have several 2200W supplies that I'm waiting to find a use for. I may repurpose them for architectural lighting.
          HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
          This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
          09-06-2024, 11:39 AM
        • japlytic
          Why hot swap server PSUs are derated for lower line voltages
          by japlytic
          I compared two 1200W units (both with active PFC) around the same manufacturing time, an ATX unit and a compact hot swap server unit: the ATX unit had 780uF input DC filtering capacitance compared to 390uF for the server unit, and the server unit had smaller PFC components (and heatsinks) for its size.
          Also, the ATX unit was rated at 1200W output under full line voltage range, but the server unit (full rating at 200-240V line input) was derated to 900W at 110-120V input and 800W at 100-110V input.
          Typically (in my belief) in a 100-120V region, server rooms have 220-240V mains...
          02-18-2019, 12:53 AM
        • harp
          Comparing FreeNAS, FTP server, SMB server, multimedia server...
          by harp
          I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
          I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
          Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
          What is general difference between this products, and what be most useful...
          01-04-2024, 02:44 PM
        • omega
          Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
          by omega
          Hello all,
          as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
          Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
          02-09-2024, 03:34 PM
        • Fireballcz
          Windows 2016 server L2TP/IPsec VPN - two subnets
          by Fireballcz
          Hello, please how to properly configure VPN in this environment?
          I have two subnets in two different (geographical) workplaces, connected via IPsec (thru gateway routers)
          Main subnet: 192.168.11.0/24, gateway (router IP) 192.168.11.1, Windows 2016 server (VPN, DHCP, DC etc.) 192.168.11.3
          2nd subnet : 192.168.22.0/24, gateway (router IP) 192.168.22.1 - just client computers.
          I need to allow external (home office) users connect via VPN server (192.168.11.3) to the 2nd subnet (192.168.22.0/24) to their computers (via RDP).
          I have no problems with VPN connection...
          07-29-2022, 03:20 AM
