Compaq Proliant 1500 PSU - unknown pins?
    Compaq Proliant 1500 from the mid 90's. The PSU fires up and a green light appears on the backplane, but no POST / no video / nothing on POST card.
    The first thing I did was test the pins from the PSU and I see most pins are labelled quite clearly and I have verified all those voltages.
    There are 4 pins on the PSU that I don't recognize from their silkscreen labels. I was hoping someone here would know?
    Pin labels that I know and check out ok:
    "5" = 5.1v
    "N5" = -5.0v
    "12" = 12.0v
    "N12" = -12.0v
    "3" = 3.4v
    "G" = Ground
    Pin labels that I don't recognize:
    "3RS" / Pink wire. Reads as 3.8v while PSU is powered but not connected to backplane, and 3.4v when connected.
    "5RS" / Red wire. Reads as 5.2v when not connected, 5.1v when connected.
    "PG" / White wire. Reads as 5.2v when not connected, 4.8v when connected.
    "SD" / Purple wire. Reads as 0v either way.
    Other info:
    - The server has an actual power switch on the front, not a momentary. I thought one of these might be a standby/soft power but there's no buttons on the case for that.
    - The intrusion protection is bypassed (microswitch that interrupts the power at the power switch if the case is open)
    - It worked when I stored it
    EDIT:
    I'm looking through schematics of other power supplies trying to find clues. Here's what I found...
    - I suspect PG is "Power Good" or the same as "PWR_OK" on some PSUs. Goes to 5v high when the PSU detects it is providing power within spec.
    - 3RS and 5RS could be "Remote Sense" - feedback into the PSU to help it make the PWR_OK decision? Detecting that the power output is as expected? Maybe the motherboard is providing that voltage back so the PSU can adjust to load?
    - SD - the only pin that is 'missing' is Standby Power for soft power buttons, but this PSU doesn't have a soft button so I don't think that's it.
    Re: Compaq Proliant 1500 PSU - unknown pins?
    follow the SD signal in the psu and see where it goes,
    some psu's have an output from the fan tacho or a temp sensor so the motherboard can monitor it.
