Philips 50PUS6262/12 (chassis TMP17.7E LA)
    Hello does anyone have a schematic of the bufferboard? or clear photos with resistors? I have one burnt resistor and one shorted smd cap.
    Re: Philips 50PUS6262/12 (chassis TMP17.7E LA)
    Post a good clear picture of your buffer board.
    Quit due to disrespect from unpaid sta,ff.
      The main thing is eliminate the short, I have replaced these caps with same physical size caps from donor boards, for resistor check the ohms of similar good resistors nearby, probably be the same.
        I have part number 50t32-sod xr bd.
        Tomorrow I will post pictures
          I did this too and I had picture for 1 second and it went off
            Ok, take that cap off again if you haven't and check the pads where it goes to see if short is gone if you have not already.
              I have no short now. But I have to do investigate more tomorrow
                And you are sure the donor was a cap, designator on board starts with a C, there are some components that look like caps but are not.
                  Recheck your solder work on the cap, was that with a new resistor also?
                    Remove the TVS protective diode assemblies and replace the resistor again with 100 (10 Om) - this is their disease in this panel and you will be happy.
                      Ah, ok, those rotten tvs diodes again, should he test them or just yank m out.
                        I changed cap c1204 and resistor r086.
                        I suppose I need to take out 2 diodes d004 and d003
                        And other side too.
                          I will try this thanx
                            Yes, the resistors R075 and R086 mostly burn out, they must be replaced and the diode assembly D004 removed. The photo shows that R075 is missing.
                              I did not removed r075. Do you now the value? Is this 10ohm too?
                              And other side I only remove d004 too?
                                Yes R075 - 100 (10 Om)
                                Remove from both sides D004.
                                  I have picture again. Thank you for helping👍🏻
                                    Yes, not for anything. Congratulations.
                                      I don't really know if they are needed or not, a little article there explaining their intended purpose: https://uk.rs-online.com/web/content...s-diodes-guide
                                        davi pee is/was always harping about how you absolutely must replace theses tvs diodes, BUT of course I wouldn't buy stock based on his recommendation, what does the rest of the brain-trust think?
