Sharp LC-32D12E - Line down screen
  • WallArt-Online
    • Aug 2013
    • 29
    • uk
    I have the above tv that has gotten a line down the screen. i have removed the back panel and done a visual inspection. On first glances i don't see any damaged components.
    What causes this sort of line?
    Many Thanks
  • mmartell
    • Oct 2013
    • 3189
    Re: Sharp LC-32D12E - Line down screen
    A failing tab bond I believe.
      Tab bond or defective LCD panel.
      This is not a Sharp TV. It is an Argos/etc. rebadge of a Vestel set, with an extremely poor LCD panel in it. That is why it failed.
      It's crazy how many of these sets are failing with panel issues now, hundreds of them all dying. And not repairable!
      • Kiberge
        Samsung LH82QENELGC/EN Help needed - Static line on screen
        by Kiberge
        HI guys!
        I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
        I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
        the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
        This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
        04-22-2024, 11:28 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • almarhum
        To fix laptop screen vertical line by working on its EDP cable
        by almarhum
        Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
        As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
        05-07-2024, 02:12 PM
      • Mad_Science
        Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
        by Mad_Science
        I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
        03-01-2024, 05:05 PM
      • scubacamper
        Sharp Aquos LC-70C6400U Half Screen Dark
        by scubacamper
        I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
        Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
        when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
        05-03-2025, 12:19 PM
