Lg 60PK550 Problem
  • fireproof710
    • Dec 2013
    • 56
    Re: Lg 60PK550 Problem
    Any further conclusions about that mystery capacitor?
    • freakaftr8
      • Oct 2012
      • 3743
      Im still lost on it. 1800v seems rather odd for a capacitor in a SMPS. Im more thinking that 1.8KHP is a 10% tolerance notation. But the 223H may in fact be .022uf
      Someone else needs to chime in on this one. A well known supplier of components buddy of mine is even lost on what that cap means...
        I have heard of 1250V capacitors, it's not too much of a stretch to imagine a 1800V capacitor existing...
        • fireproof710
          • Dec 2013
          • 56
          Would it be conceivable to consult a technical diagram of the power board to find the specs? We have a betacam deck at work from back in the day that came with a hefty manual that diagramed every board in detail. Would a similar document exist for a tv?
          • fireproof710
            • Dec 2013
            • 56
            I had somebody tell me it was a 22uf 1800v. I emailed a few component supply places and asked if they could help ID it.
            • fireproof710
              • Dec 2013
              • 56
              Digi-Key got back to me. They too think its a .022uf 1800v. They said the closest thing they had was a 2000v, but its leads are probably too short to install in the same location. Would installing a cap with a higher voltage rating screw everything up?
              http://www.digikey.com/product-detai...235-ND/1532455
              Waiting to hear back from Mouser and Jameco.
                Higher voltage rating will be fine. You could break the leads off a resistor and solder them to the leads of that capacitor as replacements.
                • fireproof710
                  • Dec 2013
                  • 56
                  Cool, I'll give that one a try. In summary, I will be ordering/replacing:
                  1) The suspected faulty mosfet and the one next to it that is the same type.
                  2)The high voltage mylar cap.
                  3)The small caps near the heat sink and all of the other small caps on the board while I'm at it.
                  Before I place the order, is there anything else I should consider replacing?
                  • fireproof710
                    • Dec 2013
                    • 56
                    Do the mosfets need thermal paste on them for contact with the heat sink? If so any recommendations?
                      Yes. Generic thermal paste hasn't failed me yet.
                      You should also replace the IC which drives those FETs, if there is one on that board, otherwise, they may fail immediately on power up. Picture of underside of board near FETs?
                      Consider building a lightbulb test jig: https://www.badcaps.net/forum/showthread.php?t=32748
                      • fireproof710
                        • Dec 2013
                        • 56
                        I'll snap a pic of the underside when I get home. What exactly is an IC?
                          Integrated circuit -- will be in charge of driving the MOSFETs.
                          • fireproof710
                            • Dec 2013
                            • 56
                            Ah, makes sense. I'll report back once I'm home and get a pic.
                            • fireproof710
                              • Dec 2013
                              • 56
                              This is the nearest IC. All of them are pretty dang small and are all soldered straight to the board. I'd have to get a hefty magnifying glass to read the markings on it.
                                That would be a suspect, I would advise replacing it.
                                • fireproof710
                                  • Dec 2013
                                  • 56
                                  Okay. I'll order the other parts so I can get some soldering practice in. God knows I'll need it for those leads on the IC. I'll report back once I've gotten a magnifying glass I can use to read the markings on the IC.
                                  • fireproof710
                                    • Dec 2013
                                    • 56
                                    Okay. Got the parts. Swapped them out. Still works intermittently. Still makes clicking noise (though more static/click hybrid sounding) from the same area. I got a loupe and looked at the numbers on the IC. It looks to be an "ST" brand circuit There are two rows of markings one at the top that I could faintly and not concretely make out as "L6591AU"
                                    The other string of characters is below and to the right of the ST logo and is indecipherable. Nothing comes up in google for the numbers that I think are stamped on there. I'm wondering if I should just get a new board at this point. I found one on ebay here:
                                    http://www.ebay.com/itm/LG-POWER-SUP...p2054897.l4275
                                    It looks to be the same numbers except my PCB number is: EAX61432501/6
                                    and the one on ebay is EAX61432501/10
                                    Thoughts?
                                    • fireproof710
                                      • Dec 2013
                                      • 56
                                      I found another one cheaper and with the exact number match. I think I'm going to go for it.
                                        Missed your post, but L6591 is probably the part #. Did you replace that chip yet? It can be difficult, but if you can remove it, then you can put it back on. No harm trying if you're going to get a new board anyway.
                                        • fireproof710
                                          • Dec 2013
                                          • 56
                                          Thanks for the reply. Googling L6591AU returned no results but leaving off the "AU" gave me what appears to be an AC/DC circuit with the same number of pins as the one on my board.
                                          http://www.digikey.com/product-detai...art_dkc_buynow
                                          I'll give it a go.
                                          • HTR-Informatique
                                            Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                            by HTR-Informatique
                                            YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                            I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                            On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                            I also changed the screen because the PC fell and the screen was broken.
                                            I changed the battery with a new and original battery.
                                            I also had corrosion/oxidation on the...
                                            02-09-2025, 06:51 AM
                                          • boyebaran
                                            hisense 65k560 back light problem
                                            by boyebaran
                                            hi to all
                                            tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
                                            in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
                                            please advise me tnx
                                            05-20-2025, 07:11 AM
                                          • theone111
                                            by theone111
                                            3. Problem: TV shuts down
                                            07-22-2024, 10:36 AM
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
