LG 60PV450-UA Testing Main Board
  • weimars
    • Dec 2013
    • 13
    I've got an LG 60PV450 plasma that I'm diagnosing a no picture problem, but has sound.
    INFO:
    The voltages are all in spec.
    The tv powers on and stays on with sound transmitted.
    In a dark room you can see that the screen does have a glow to it.
    I have used a jumper on the CTRL board to get test patterns (w/ the LVDS cable disconnected) and the patterns display with no lines and look excellent.
    QUESTIONS:
    Do I conclude that the CTRL board is fine considering the results of the test pattern?
    How do I test the main (input) board to confirm it's the source of the problem?
    Thanks!
    Re: LG 60PV450-UA Testing Main Board
    There is a rare chance the control board is bad, if its input circuit is bad.
    The main board is most likely the cause.
    Without an oscilloscope you can't test the signals between the main and control to see which could be bad. So you would have to try both.
    • weimars
      • Dec 2013
      • 13
      I tried a replacement control board and it has the same problem with nothing changed. So I've ordered a replacement main board and hopefully that'll solve the problem. I'll update when I give it a go.
      • weimars
        • Dec 2013
        • 13
        UPDATE:
        I went ahead and bought a new main board for this tv, since my replacement control board didn't seem to change anything, and it works like a dream! I've had it on during the day now for about 3 days and it has performed flawlessly. I actually think it has a pretty good picture.
        Thank you tom66 for your reply and thinking the problem through with me!
          Glad to hear! Enjoy your TV.
          • jerrmrz
            • May 2014
            I have the same tv with no picture but has sound..... first started showing signs of possible burn in on top and bottom of screens but now if black with grey patterns on screen.... unable to get a test signal
            • GTech6261
              • Jul 2014
              • 3
              I have a LG60PV450 with no picture or sound. A service tech says (for an 85$ service call) it is the XMain board but since none can be found, I should just trash it and buy a new TV! It is only 30 years old, I dont mind risking it with a used board if anyone knows how to find one?
              • GTech6261
                • Jul 2014
                • 3
                I meant 3 years old..
                • chancleta
                  • Apr 2014
                  • 4
                  • Puerto Rico
                  I have a LG60PV450 with no picture or sound. i test the buffer board and it seem to be ok the only thing that i see is the blinking led on the t com board can some body can help me ???
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • ygorsan
                    by ygorsan
                    🧩 Problem Summary:
                    • I
                    07-28-2025, 08:34 AM
                  • jb_Bak
                    by jb_Bak
                    CN6401
                    Pin 01 NC
                    Pin 02 NC
                    Pin 03 "BL_ON": 0V
                    Pin 04 "N/C"
                    Pin 05 "STBY 3.3V": 3.5V
                    Pin 06 "GND": N/C
                    Pin 07 "AC_OFF"...
                    09-27-2021, 04:52 PM
                  • JDC
                    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                    by JDC
                    ONN 100012588
                    Issue: No Power, Then Rebooting After Main Board Change
                    Short answer: replace main board and power board
                    Technical answer: replace main board and Q306 & Q307 on power board.
                    Long answer:
                    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                    07-15-2022, 07:39 AM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
