62 ohm... that should be OK... so when you put it in place do you see any glow from the screen?
If not you would need to connect another resistor of around the same value (100 to 470 ohm ideally, a little less is OK) from 5V to VS ON.
It's blue red black gold which is 62 ohm.
Gold is last band.
Third band generally black or brown only, to help narrow it down.
Right ok well I get the power board to click once and stay on using one resistor so does that tell me there is a fault with the A board if when I plug that in I get constant clicking ?
No, because the control board could cause the clicking once the main board sends the 2nd ON/OFF (VS ON) to power board. It's important to bring the board up completely and have test patterns or you can't tell if control, main or y-main/x-main are at fault.
Nope. You need VS ON to get VS and VA.
Stick some 100 ohm through hole resistors in that CPC order and keep them for future tests... will cost less than £1.
1st pic looks OK, so do you have Vs/Va and glow from panel?
As for the two sets of pins... that's a good one. Never had that before. I think it's CN2008.
After a few seconds of clicks and whining sounds from PSU, Vs/Va should come up. Could take around 5 seconds to screen glow. Once glowing a few more seconds to test patterns.
Just one green flashing light from the t con there is 2 lights on there one flashes once then the other keeps flashing I'm getting the right values from vs and va though
Check screen carefully for glow. Try without jumper. Anything?
