What is the best way to remove the screen on these borderless set? And what tape to use to resecure screen after replacing backlights? Thanks
Best Buy 50LF621U21 Backlight Repair
Business card, I use cardboard one for edgeless because it'll allow a 90 bend instead of a stiff card. The foam tears through pretty easy. If you have a suction cup towards the edge of the screen as you slide and gently pull up it works great.
Just go to eBay and type tv foam tape, it'll show up. Generally the foam tape if you grab the very edge you can pull it up in one piece once the screen is off.. if that's the route your going
