4 red flash led 65X950G boot Sony and android logo but then black
    • 12305
    • U.S.
    My xbrx900c, gave me both 4 and 6 blinks at different times, tore it apart which WAS a major pain in the ass, backlights were fine.
      • 12305
      • U.S.
      Originally posted by Storyteller12
      In terms of troubleshooting you are correct and Sonys manual states that as well. Sony only tries that because the tech can change the boards. They never tear apart and replace backlights. They provide new panel with backlights and reinstall your old boards or replace tv altogether
      However I have fixed a lot of these Sonys and never had ld board be bad. It's always the backlights
      So of all of them you never had one that triggered the bl-error pin that was something other than burned out leds? I stay away from them as much as I can but have seen where the over-current circuit is wonky and too sensitive and can trigger the shutdowns, in some cases, not referring to when a backlight is actually bad of course.
      • Ihandyrepair
        • Sep 2017
        • 44
        Sorry to hear that
        that is why I wanted to be sure before opening up
        but mine is for sure is led strip issue
        just wondering if anyone had replaced Sony led strips
        where you ordered and are they OEM
        or most are Chinese copies or refurbished
        worry that buying wrong ones they trend to burnt easy
        I had replaced Samsung strips and they started to burnt again after a year and they werent cheap crap from Chinese website
        even I lowered the brightness to 50% right after replacing them
          • 12305
          • U.S.
          You're at the right place to ask, maybe someone can send you a pm of a trusted seller, will probably be from aliexpress.
          • Storyteller12
            • Jun 2020
            • 625
            Never had one that wasn’t backlight related. You are right about them being sensitive to change though. These Sonys use a specific led that powers at 12v. Not the typical 3v or 6v led. When they start to fail they can draw a little too much current or just under 12v and cause the error
            • Storyteller12
              • Jun 2020
              • 625
              Originally posted by Ihandyrepair
              Sorry to hear that
              Cross reference shopjimmy.com for your tv mode # to ge the backlight part #. Then check eBay or Aliexpress. All backlights come from China. It is what it is. Just turn down the brightness and you should be good
              • Ihandyrepair
                • Sep 2017
                • 44
                Hi
                I just got reply from shojimmy
                they said there are no oem led strips unless from used tv
                most led strip aftermaket are made in china
                so my question for you guys
                do you replace all led strips with aftermaket led strips when you have under 3 led strips to replace
                or you just change only the burnt ones
                I read some forum saying it is better to replace all
                incase the voltage difference on the new and old
                or that old ones might burnt soon too
                others say new strips are cheap make trend to burn sooner
                  • 12305
                  • U.S.
                  #28
                  Yep replace all of them, from a trusted supplier, you don't want to go thru all the trouble of tearing it down again in the near future, it's a pain and there's always the risk of breaking the panel.
                    • 12305
                    • U.S.
                    #29
                    Two there, didn't look very hard for a great deal so don't know if there is any.: https://www.aliexpress.us/item/32568...Cquery_from%3A https://www.shopjimmy.com/sony-mbl-6...ght-strips-20/
                    • Teban1306
                      [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                      by Teban1306
                      Hello everyone!
                      I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                      System Information:
                      • Model: Lenovo ThinkPad T14 Gen 1
                      • Machine Type: 20S1S4E600 (Intel i7 variant)
                      • Current BIOS: N2XET42W (1.33) - Latest version
                      • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                      What I'm trying to achieve:
                      Replace the default "LENOVO" boot logo with a custom image during POST.
                      🔧 What I've tried:
                      09-14-2025, 11:49 AM
                    • reassor
                      Sony kd70xf8305 very very slow android logo with sound
                      by reassor
                      Hi.
                      Power is ok
                      Tv turns on by it self when you turn IT off with button or pług.it shows sony logo the android logo but with like 1 frame every 10 sec. Music starts after like 1 min. After some time logo will Just hang. But i can turn volume up and down on a pilote but its very slow as well.
                      Should i force update? If so how?
                      I did reset.
                      Mainboard Looks pristine.
                      Very wierd.
                      10-30-2023, 05:59 AM
                    • rvh
                      Repairing a Sony KD-49X8309 tv (android boot loop)
                      by rvh
                      I got a Sony led tv, that's stuck in a boot loop. It won't go any further the android screen and won't turn on further. The indicator light turns up white, and then it comes in a boot loop
                      It seems, that all of the Sony tv of this X-range will end with these problems after 2-3 years or so.
                      Television
                      Sony KD-49X8309c
                      Main board
                      1-894-595-12
                      Y210B300c
                      Sony BMFW
                      Panel:
                      SYV4941
                      The problem is the mainboard. That's confirmed by Sony.
                      After some googling, i came...
                      02-26-2020, 05:53 PM
                    • mauda
                      Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                      by mauda
                      I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                      Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                      05-21-2023, 11:56 PM
                    • JaquesPratt
                      Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                      by JaquesPratt
                      I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                      This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                      07-16-2024, 01:04 AM
