Samsung UE55D8090 Power On/Off
    Hello guys , i have problem with a Samsung UE55D8090
    Always Power ON/OFF all 2-3sec. (Only see briefly SMART LOGO) before was problem TV start sometimes and working and now only restart always , eeprom was reset with SDA+Reset short with cable. reflow cpu and change Emmc still its same hope anyone can help me
    Thanks in advance
    freeze with spray IC1302 , when it come to life keep freezing put it in STB and call service menu INFO - MENÜ - MUTE - POWER and from there do hard reset
      Thank you Diah but still same , possible need a good working dump , i programm only emmc with other working dump
        On this chassis, dump eMMC should have exactly the same firmware version as OneNAND.
          Thanks guys for help i understand , can anyone send me dump ?
          would be very nice
            i would think you did testing the LED BL by unplug main from PSU... or?
              What software version do you have?
                trouble shooting... see how you can run fimware from standby mode..
                this link had 26 dumps of samsung TV hope yours there
                  Version is 1018.0 on emmc , i try unplug cable from PSU no backlight
                    In these models (D7000, D8000), the backlight will not work when the motherboard is turned off, most likely your backlight is faulty, if the firmware is faulty, your TV should work for 10-15 seconds, then a restart occurs, if the backlight is not working, then the restart occurs after 3-5 seconds (after the Samsung splash screen). So you need to check the backlight first.
                      Iam back and have change backlight but still its same
                      Last option is write a good dump , if anyone can help with that i will be appreciative
                      Best regards
                        You need to know exactly what software version you have now, what is written on the emmc tag is not accurate, since the TV could be updated several times over the network and the software version will change, do you have time to enter service mode?
                          Have download emmc dump from gsmforum.ru without nand dump , tv always reboot 2 second 😅
                            But you need to know what version of the software is currently installed on TV (1018,1019,1021)
                            I have 1018.1, 1019.2.
                              Have 1018 on emmc
                                I gave a link in a personal message to the dump eMMC section USER ver. 1018.1
                                  Thanks a lot lotas
                                    PM full dump 1019.2 (eMMC, OneNAND, EEPROM)
                                      Hello guys now iam back from holidays and found little time for programm for new Onenand+New Emmc
                                      THANKS User lotas who help me 😁 Tv now start but approx 10sec he going off .Service Menü also try factory reset without Sucess.
                                        So maybe your OneNAND has bad blocks and the dump data ends up on these blocks...
