Hisense 58r6e3 black screen dumpster dive
  • Jne2016
    • Jul 2024
    • 6
    Hello all,
    I was driving around and found a free hisense r6e3.
    I figured what the he'll I fixed a free tv before with a new lamp.
    So I plugged it in and got sound but no picture i see it light up though.
    I've tried using a flashlight to see a faint image no luck.
    I've tried unplugging a ribbon cable off the tcon board and the left side shows white when right is unplugged. All black when right is in.
    I saw a video were someone taped off some off the ribbon and it worked but I don't know how you find which pins to block off. And if that wont work whats the next steps to test so i could fix it.
    I've been reading and seen the main board and power board go out alot but how do itest before buying random parts.
    Thank you all for any help.
  • handsworth
    • Oct 2015
    • 175
    Would help to know full model # as we dont know what size tv you have. Also pictures of the boards are extremely helpful too.
    • Jne2016
      • Jul 2024
      • 6
      Sorry mode is 58r6e3
        • 12335
        • U.S.
        See if those 2 capacitors are perfectly flat on top, looks like one is bulging, any bulge at all and it's bad.
        • EazyBone
          • Jun 2023
          • 1364
          • United states
          I've seen a few of these, try tape. Likely the panel shorted. Not sure why but the 58 size gets panel shorts. No need to use flashlight if TV lights up.
          • EazyBone
            • Jun 2023
            • 1364
            • United states
            Also, taping method is sort of random, try to block 6-12 pins at a time. Only on one side at a time. Generally you are blocking pins on the left or right side and not the middle. Put some tape, plug ribbon back in, plug in tv, hit power see if a picture. Do NOT plug in TV or have TV plugged in when moving any ribbons, they will short out potentially.
            If the TV doesn't show picture you can unplug the tv immediately and resear your tape to new pins, then replug in. Should go quickly.
            Id say 90 percent sure it's a panel short. So don't buy any boards until you get all the tape spots and report back
            • Jne2016
              • Jul 2024
              • 6
              I tried a bunch of times with the tape no luck.
              I took a Pic of the caps and is this one on left considered bulging
                • 12335
                • U.S.
                Yes it's bad, replace it and retry tv.
                • frannyjunk
                  Hisense 40H4F no backlight but turns off after splash screen
                  by frannyjunk
                  So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                  TIA.
                  09-24-2025, 10:59 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
                • Runlinc
                  Hisense 55E76GQTUK screen removal?
                  by Runlinc
                  Hi all, I need to change the backlights in a Hisense 55E76GQTUK. The screen is glued to the chassis, what is the easiest way of delaminating the screen from the chassis please?
                  also what double sided tape would you recommend to glue it back in? ….. or is that a question to ask once the screen is out in one piece?
                  Many thanks for any ideas you have.
                  04-09-2024, 10:02 AM
