Originally posted by dfear
View Post
hitachi 75hl16t64u - not responding to remote control
I have taken many voltage readings on both original and replacement main boards and IR sensor boards.
Here are the results:
Voltage results are in pin order (1-5).
Original main board.
Original IR Sensor
STANDBY
Gnd
2.96
.223
.026 or .077
11.85
ON
Gnd
.0215
11.59
.0765
11.83
Replacement IR Sensor
STANDBY
Gnd
2.84
.230
.078
11.85
ON
Gnd
.0215
11.59
.077
11.83
Replacement main board.
Original IR Sensor
STANDBY
Gnd
2.97
.233
5.57
11.85
ON
Gnd
.0217
11.58
5.575
11.83
STANDBY
Gnd
2.84
.239
5.56
11.85
ON
Gnd
.0214
11.58
5.56
11.84
The only significant difference in voltage in the pin 4 voltage reading. The difference in readings readings between the original main board and the the replacement main board is what the TV is doing. The original main board was only displaying the no input signal message and the replacement main board was displaying the first time setup wizard.
It's hard to tell exactly what you have done as to the suggestions, so if you have not, do exactly this for my test. take batteries out of remote, hold on/off button on remote down for 1 whole minute let go, then push ALL the other buttons several times give them good pushes not just light, unplug tv from power, hold the power on/joystick whatever button the tv has down for 30 seconds, wait 2 minutes, plug tv back in, put batteries back in remote and try it. If still the same try a universal remote, just see if it will power on the tv, we just want to see if a remote can communicate with the tv.Quit due to disrespect from unpaid sta,ff.
I can not help if tests are not performed and reported, it just makes it too hard. Remote troubleshooting is pretty much working in the blind, so you need very precise communication and directions followed.Last edited by nomoresonys; 09-03-2024, 10:57 AM.Quit due to disrespect from unpaid sta,ff.
Originally posted by yokoono View Post1. The motherboard was replaced with another one from a different TV model with a different code for the remote control
2. A software was rewritten from another model of TV using another model of remote control
3. Use a programmable TV remote control (memorized codes).
Originally posted by vinceroger69 View Post
I was also thinking this too i wonder if the owner swapped the mainboard out themselves when that did not fix it , they took it to a repair shop now psu sorted now the tv is now having this issue as wrong mainboard
This TV was working until the issue with the power supply board occurred. The main board and the ir sensor board are (to the best of my knowledge) the one from the factory and are "paired" together. The replacement main board and sensor boards are quite possible not.
FYI: I am the repair shop.
