Display issue Samsung TV UA65JS9000W
  • FourRunner
    • Oct 2024
    • 6
    I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and there is evidence of burning from the LED's, are replacements available?
  • FourRunner
    • Oct 2024
    • 6
    This is an actual photo of my TV rather than someone else's photo who had the same issue that was posted on another forum, however they did not any responce to their issue.
    • EazyBone
      • Jun 2023
      • 1351
      • United states
      Your sheet was unusable because of the cracks. No getting around that. When changing out backlights on Samsung, once you put the lights in and the diffuser sheet, before you put the screen back on... You disconnect the main board connector from the PSU and plug it in. This will turn the lights on and you can see any defects on clips that aren't connected that will cause bright spots on the screen..
      Those cracks will always show that you need to replace the diffuser sheet as well and you can't really buy them in my experience. And if you can they're super expensive. So usually you find a broken screen TV that didn't have the lights melt the shield and you transplant it off of that instead
      • FourRunner
        • Oct 2024
        • 6
        Thanks for the feed back. Do you know what material the thick clear sheet is made from? If I can find this out and it is not some special material I should be able to have a local supplier cut a sheet to size and use this as a replacement. I guess my main issue is the darker centre of the screen.
        • FourRunner
          • Oct 2024
          • 6
          I'm now convinced from what you said that the darkening of the screen is caused by the diffuser sheet. I will try my local TV repair shop to see if they have any good secondhand sheets available. Not a great design on Samsung's behalf.
          • KYBOSH
            • Oct 2011
            • 581
            • Unknown
            This is par for the course on edge lit displays. First thing you have to on these technologies is to turn the brightness DOWN. As far down as you are willing to endure in your TV watching. The LEDs burn way too hot for the diffuser/reflector material to withstand. As the resistance of the LEDs increase (with age) the hotter they get. They begin to char and often crack he diffuser/reflector. Nothing can really be done to save it once this happens. You will need to find a salvage TV (the same model TV) and see if you can pull the reflector/diffuser from it ...it its any good. I heard of ppl wanting to take the sheet from a larger TV and cutting it to size. That MAY work if your cuts are not on the side where the LEDs are. You'd have to be lucky to find what you are looking for though. I kept a 65" SUHD for almost a year waiting for a donor TV and never found one. Then i parted mine out and stored/offered the diffuser/refector to anyone who may want to use it for a smaller TV. No one ever inquired.
            Good luck
            • Storyteller12
              • Jun 2020
              • 625
              There is only 2 TVs Samsung made with these edgelit panels on the side. The JS series you have and the HU series the year prior. Every other tv edgelit is lit from the bottom. You may get lucky but usually TVs this old all the diffusers are in bad shape some way or another. Will never be perfect again
              • EazyBone
                • Jun 2023
                • 1351
                • United states
                I just got a HU series one with edgelit like this. Pain in the ass!!! To tear down. I got there, and the sheet was cracked. I put the screen back took the parts off and tossed it. No way I'm finding another one of these.. been a year and this was the only one I've found. Story is right, impossible to find for most.
                • Sam Scarbo
                  • Oct 2023
                  • 38
                  I believe have a similar screen problem for my SAMSUNG LN40B530P7F. See photo. It was supposed to show a pure grey picture but it ended up showing brighter on the left (lower-left corner the brightest) and very dark on the right.
                  Not only the left side of screen is brighter but the contrast is better. When used as a computer monitor, I could recognize the texts displayed on the left but couldn't recognize those very well from center to the right.
                  I thought it was LCD panel issue. I tried a new T-con board, but same issue. I made voltage measurements here and there, and broke a flat cable connection, leaving a vertical black band on the screen. I gave up.
                  Could it be the same diffuser issue? Thanks for any comments for this.
                  • EazyBone
                    • Jun 2023
                    • 1351
                    • United states
                    That looks like a screen fault. Diffuser is a totally different thing, a perfect picture would be behind it still. Looks like a plasma TV anyway
                    • Sam Scarbo
                      • Oct 2023
                      • 38
                      That is a LCD TV. Thanks for the reply.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4425
                        • Italy - Milan
                        I hate threads hijackers.. anyway (to the OP) i think someone else put the hands inside it before you, not a technician surely, the fresnel sheet is probably upside down or more probably the sequence is not right.. usually the thickest behind, thickness decreasing towards the front..
                        • Kjell
                          Samsung Series 9 - BIOS issue
                          by Kjell
                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                          08-01-2025, 09:15 AM
                          09-07-2024, 05:50 AM
                        • Nairolf
                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                          by Nairolf
                          I have a Samsung DM32D display.
                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                          Here’s what I have tried so far:
                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                          08-24-2025, 03:47 AM
                        • vincentedel
                          Samsung SyncMaster 740n Phase Control Issue
                          by vincentedel
                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                          04-22-2025, 12:33 AM
                        • Manucsl
                          QE65Q800TATXXC Samsung TV Issue
                          by Manucsl
                          Hello.
                          My TV is a QE65Q800TATXXC Samsung TV.
                          Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                          Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                          Any ideas to check would be very appreciated 😊
                          After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                          02-19-2025, 07:47 AM
