Horizontal lines LG OLED65C98LB
    Click image for larger version  Name:	IMG_3906.png Views:	0 Size:	2.73 MB ID:	3513115Hi all. I am following a few threads up here with high interest, because I like to see pestle fixing their stuff. Now I got a OLED that has an issue I try to fix. Maybe some of you have an idea since I was not successful so far. I see horizontal lines with different brightness starting from left over a little lite that half of the screen. They also appear when I start P_only mode. So I guess it is the t con. Sometimes they do not appear, but usually they appear after a few minutes and only disappear after power cycling. I tried to make a picture but it is hard due to artifacts by camera. Model is a LG 65C98LB. Any idea or suggestion highly appreciated. Thanks in advance! Cheers
    But what type of image are you displaying here in the photo? Is the image subject intact or distorted? Due to my comprension of english i ask if the thin lines fades out from the start to the end of the row.. Do this test, when the defect appears, spray ice cold gas under the bga chips on tcon, if the defect decreases, then you can start searching another tcon, get one from sure working set *cracked panel*, break the seller's ball to ensure both data.. good luck..
      first of all thanks for your the reply! and nice profile pic, I have some Amigas sorry for being imprecise here. the pic shows the distortion, the brighter lines. Indeed the lines fade out from left to right. Ok I will try, Thanks for your suggestion!
