The TV sometimes turns on fine, sometimes it doesnt.
Checked the PS voltages to find that PS_On sometimes reads 1.1v and drops off to around 0.9v which is enough for the tv to turn on, other times theres no voltage reading or around 0.7v which is not enough to switch on, would think this should be around 3.3v.
So disconnected the ps_on wire between main and psu and jumpered a 1k ohm resistor across the ps_on and one of the 3.5v stby pins - the ps board powers up fine and the tv turns on when power button pressed but of course its less than ideal leaving it like this as the power board will remain awake constantly. Whilst its wired up like this the ps_on from the main thats disconnected is now actually reading 3.5v, which is what I would expect it to be.
How can I narrow it down more? On the main theres a MMBT3906 transistor which provides the ps_on signal - is this the likely culprit?
Main : EAX644320B-1.0
PSU : EAX64310801 (1.3)
