I have a 42" Vizio here model SV420M that has a normal vizio logo,that lights up amber color when in standby mode, then the normal white when powered on. has no backlight, black screen and no sound,
I measured voltages on the power supply board connectors and got 5.2 v on +5VSB.... PSON had .27V when powered on and 0V when powered off...On/Off Inverter had .05 volts when powered off and 2.16V when tv powered on. 12V is not present, I checked both fuses on the main board both are good, one on the left has 5.2 V, one on the right has 0V on both ends, resistance on fuses showed continuity so neither one is open.I think the fuse on the right is on the 12V supply but for some reason I'm not getting the 12Volts.
I'm thinking a mainboard problem instead of the PS board, also no voltage on regulator U6 ( checked it for shorts was okay in circuit ) as someone else had with the same model TV, Any help suggestions of what to check next is greatly appreciated. Thanks
