Soooo, I found someone giving away their 70" Vizio TV because it wouldn't turn on. Hoping it would be just some bad caps, I snapped it up. No dice. No bulging caps. TV would start consuming about 7W immediately after plugging it in, but no response from the remote or power button. Thermal showed the main chip on the mobo getting warm and nothing else. Power supply appeared to deliver stable 12V to the mainboard.
I ordered a replacement mobo(actually both mobo and PSU just to be sure) and popped it in. Picture! Sound! Endorphins! Then I noticed three long dark strips. Hmmm, had to be bad strips. Instead of just ordering a full set of strips, I ordered 1000 LEDs from China. Because what says fun like spending hours SMD soldering dozens and dozens of 3030 packages and saving $20? Well, more like $13 because I had to buy a proper hotplate. I mean, if we're going to call one of those 5CM square $7 aliexpress hotplates "proper." I wouldn't. But anyway. After spending several hours fixing the hotplate, because it was most definitely not proper, I was ready to rock.
I snapped off the lenses to prepare to swap the LEDs. I started to go too fast and I did this while handling one of the crunchier strips. The strips in the middle of the TV were visibly yellower than the surrounding strips, and the lenses were more brittle, too. I obliterated one of those crunchybois. I ordered a set of PCBs with LED and a lens for like $7 on papa bezos' site. I was able to snap off the lens and glue it on the original strip. The result wasn't too bad. It wasn't perfect, but it was better than my first attempt where I tried to use a lens from a Samsung. I also tried a Samsung LED with the Samsung lens and that was even more noticeable, so that's when I got the pack of PCBs with lenses.
After putting everything back together, exactly the way it came apart(I taped the filters) I am greeted with not 3 very dead zones, but 144 dimmer zones. I didn't notice it right away, but as soon as it went to a monotone solid color it was like BAM. I put a JPG on a thumbdrive that's solid 127127127 grey, and here's this:
