How to fix Hisense 43A6H 4k Google TV - 10 Blinks?
    Hi I replaced the mainboard, the t-con, and wifi, still no dice.
    Any idea on what it could be, causing the tv to not turn on? Just blinking LED light.
    Processor gets hot so I know the Mediatek MT9612 is functional.
ID:	3594026 Click image for larger version
    Last edited by chris89; 03-15-2025, 06:54 PM. Reason: Adding pictures if it helps?
    Does backlights come on when you hit power?
    If not take a flashlight to the screen after hitting power and look for image.
      Sounds like the TV version of an RROD. Unfortunately, you will have a replace one or more components, most likely.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
        Non stop blinking led on Hisense usually means no Internet connection. So probably not rrod. Still should check if backlights are working
          Test the Backlights with a Backlight Tester. Most likely the Backlights are defective.
