Panasonic TC-L42U12
  • AWTVs
    • Jun 2014
    • 27
    • US
    Panasonic TC-L42U12
    This tv is completely dead. No lights, no sound, no blinking, no bulging caps! The fuse appears to be soldered in. Not sure what to do; I'm open to any suggestions.
    • 31139
    Re: Panasonic TC-L42U12
    you need a meter to test the fuses - i see atleast 2.
    • selldoor
      Slow Learner
      • 7870
      Click on the red box with an exclamation mark in and report the thread- ask a mod if they will please move it to the troubleshooting TV section - cant understand why you posed it here!
      • AWTVs
        • Jun 2014
        • 27
        • US
        Thanks stj for your reply. I see the obvious fuse but not sure of another one. Do I need to remove the board and test these out of circuit? Any details you could provide is appreciated.
        Hey selldoor - I requested this thread to be relocated. New to the forum space; thanks for the heads up.
        • selldoor
          Slow Learner
          • 7870
          You will need to remove the board. When it out take a good clear picture of the bottom.
          There is a red box fuse - bottom left corner on your picture half an inch from the edge.
          Will probably say F??? beside it.
          You can test in circuit. No power to the board -meter on ohms 200 good fuse will read same as touching the probes together
          • AWTVs
            • Jun 2014
            • 27
            • US
            Thanks selldoor for response. I took out board and tested red fuse in circuit and got OL. I'm not sure about the white fuse. It appears to be riveted in and not sure if I can test in circuit or if it's ok to remove the rivets. I tested it in circuit and got intermittent readings. I apologize but I'm quite the novice currently. I am attaching hopefully clearer pics of top and bottom of the board.
            • AWTVs
              • Jun 2014
              • 27
              • US
              Additional image
              • selldoor
                Slow Learner
                • 7870
                OK I was looking earlier but couldnt see what amps the red fuse is. I think I see now it is 1.6amps. You will need to get a new one but perhaps you can find another type that will do to test more cheaply. You do need to test that other fuse - it should test the same way - perhaps try on the solder joints at the back of the board.
                Next test after that is a HIGH voltage test just on that board.
                You need to work on a non conductive surface and use a rcd if you have one. Also have someone else in the house if possible.
                So set your meter on 600vdc and CAREFULLY put one lead on each leg of one of the pair of the BIG capacitors - should be 300-400 volts.
                Perhaps try a dummy run to practice holding the probes and watching the meter without power to the board. Then power it up and test on both caps. Then unplug and leave for 5 minutes
                • AWTVs
                  • Jun 2014
                  • 27
                  • US
                  Thanks for the response.
                  Will most any 1.6 fuse work as replacement for the red fuse? It appears the white fuse is 16.3amps; if I am not able to get that reading then I suppose replace that one too? I assume I can remove the rivets and just re-solder the replacement in? Nervous about the testing of the high voltages. I assume I reconnect board and test while its powered up correct? If those caps are less than 300-400, then replace? I considered just replacing the board but haven't been able to find one yet. Any next steps if these fuses and caps are bad and replaced but no change?
                  • selldoor
                    Slow Learner
                    • 7870
                    No white fuse is a T 6.3A the fuse should be the same amps and as they are mains voltage fuses same voltage. You can use household glass ones but you should tape round them so the glass doesnt go everywhere if it shatters. Problem is 6.3 and 1.6 are not common household sizes. You might get away with 5A and 1A just for testing but be aware they might blow. You can piggyback fuses for testing as well just solder the new one over the old one - would work for the white one. the red one if you can get a fuse and fuse holder you can solder wires to the underside of the board or to the
                    holes when the old one is removed.
                    You dont need the board back in the set to check the BIG caps just have that board on its own and plug it in when you are ready to do the test. - If the white fuse has gone
                    there will be no voltage at the big caps anyway.
                    • riparo
                      Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
                      by riparo
                      Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
                      I attach a link to download the service manual, thank you for anyone who can help me
                      https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
                      01-11-2024, 12:35 PM
                    • CoinCoin88
                      Panasonic PF50G20S blinking 13 times
                      by CoinCoin88
                      Hello there,
                      Google led me again to badcaps when trying to troubleshoot a dying Plasma that is sitting at my uncle's roughly 550 km from where I am. It's an old G20 from 2010 or so, that isn't being actively used so you can consider the panel "not too sollicitated".
                      Symptoms: TV starts, works for 5-10 minutes, then screen turns black and safety kicks in and spits a 13-blink code with the red LED. Once this code kicks in, the TV will not display any image anymore. Unplug it for a few minutes, plug it again, it'll work then fail a few minutes later.
                      06-30-2023, 05:43 AM
                    • Andre Gilbert
                      by Andre Gilbert
                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                      11-20-2024, 08:52 PM
                    • ItepK
                      Panasonic TX-P42G30E green light blinking, no video, no audio
                      by ItepK
                      Hey everyone!
                      I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                      This post describes my entire troubleshooting process of this TV.
                      When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                      I've taken the unit apart, and I've started to check some voltages:
                      • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                      12-22-2023, 05:06 AM
                    • Tof
                      Panasonic Oled TX-65FZ800E, no picture, red led blinking every 4 sec
                      by Tof
                      Hello everyone, here is the issue I am facing with my Panasonic Oled TX-65FZ800e.
                      When the TV has not be used for some hours, I power up the TV with a video input and the image is displayed perfectly for 30seconds and then the TV switch off with the red light blinking every 4 seconds for ever.
                      The service manual explanation: EVDD_SOS (EVDD 24V error) with check point (oled panel, P board, A board, T-CON)
                      I opened it and found a burned connector on PB-board on the 24V pins.
                      The 24V wires have change a bit of color due to the overheat and the corresponding...
                      02-01-2022, 03:18 PM
