Dynex lcd 2 sec to black issue
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Re: Dynex lcd 2 sec to black issue
    No I haven't. I wasn't sure if I could do that or not cause the backlight gets 24v but does have a bl on. What would psu be. The power on circuit.
    • audiofreak19
      • Apr 2013
      • 556
      • usa
      So I tried forcing the backlights on while the main was unplugged. I jumped 5v to ps on an 5v to bon and the back light lit up for 2 sec and then shut off. So I have no idea what to check next. Anybody got any input. Getting frustrated with this one.
      • audiofreak19
        • Apr 2013
        • 556
        • usa
        So I looked at the panel schematics under the inverter section and all the conditions the inverter needs to see to be functional are all present on the inverter when it's off. The only thing I can think of is somethig with those bulbs. But I just don't understand it and I don't know where to get any.
        • audiofreak19
          • Apr 2013
          • 556
          • usa
          I called ccfl warehouse and they don't sell any other kind of bulb other then the regular probe ends. So basically I think I might be screwed on this one.
          • Locutor13
            • Oct 2013
            • 61
            Hi, I have the same Dinex DX-46l150A11 with the same problem of getting the 2 sec the black issue after replacing the same ccfl (not original) of T6. Has anyone been able to find a solution?? Please Help.
            • Locutor13
              • Oct 2013
              • 61
              I was able to remove the protection of the backlight by shorting the pin 14 "Timer" of the chip U201 to ground as shown in the attached picture. Also you will see next to the chip a series of jumpers J213,J219,J209,J208,J212 & J211 each one for smalls caps or resistors and each has two small semi circles.
              If you know the right combination you can match the settings of the ccfl according to the specifications of the protection by shorting some of those semi circles.
              Be aware that removing the protection should be done only for testing purposes as if posses a serious fire hazard.
              • wizard13
                Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                by wizard13
                I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                I have checked the forum and the available documentation but could not find a solution specific to my issue.
                • Brand & Model: Dynabook Satellite Pro C50D-B-100
                • Part Number (P/N): PYU13E-00C00PFR
                • Serial Number (S/N): 22028896H
                • System Configuration (SC): A1PYU13E1127
                • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                • Power Input: DC 19V –
                02-28-2025, 02:43 AM
              • Ancient1
                Strange LG TV issue : Image vertical lines in black screen
                by Ancient1
                Hi
                Asking for a friend.
                I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                but here its the opposite !
                TV has new T-con = same issue
                A missing panel voltage would have global effect
                So , what should one do ? how can I find where the fault is ?
                Thanks !...
                02-05-2025, 03:37 PM
              • ChIck3n
                Dell u2311h 20000 seconds to black issue
                by ChIck3n
                So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
                09-09-2024, 11:44 AM
              • Stephen
                MacBook Pro 13" 2017 A1708 Black screen issue (not flexgate)
                by Stephen
                This is not a flexgate issue.
                The lcd turns on and functions fully and fine. When installing or even attempting to install an OS the screen goes black and doesn't turn on. We swapped the LCD with a testing LCD (that works) and it too is also black. After the computer cools down it turns back on and show the screen again and then it goes black when it gets hot. Sounds like a CPU issue to me (since these do not have their own dedicated GPU) but I may be wrong. Has anyone experienced this with this model? Battery is good btw. also I disconnected the battery and it still does the...
                06-10-2021, 09:09 AM
              • sgcampion
                Asus rog strix scar 17 G733QR display Issue(flicker, black/white))
                by sgcampion
                My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
                In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....
                10-24-2023, 09:39 AM
