Pilot 37" LCD : PIL37AV Stuck on standby
  • s_henya
    • Jan 2011
    • 483
    • Israel
    Re: Pilot 37" LCD : PIL37AV Stuck on standby
    i tried the resistance testing but i have caps in paralllel to the outputs,
    so when i am testing i can see them charge, and the output on the multimeter changes...
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      if you see them charging sounds like the rails arnt shorted,does meter go out of range when they get to a point?
      did you re-solder cold joint?(resistor)
      test all your diodes,and the ones on heatsinks too?
      your controller IC 8 legged chip you put up,measure resistance from pin 7 to 8,reading?
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • s_henya
        • Jan 2011
        • 483
        • Israel
        i tested on the 2k scale, some has went over it, some didn't.
        i tried resolder everything i took out, but i have no way to verify as i solder caps the closest to the pcb, so i cant look under the caps...
        about the diodes with heatsink i will have to wick the legs because some are connected in parallel to tansformers/resistors.... -> i will do it tommorow and update, it 1am here at israel...
        to test the ic should i remove it out, or i can test it in circuit?
        • multimeter
          • Jan 2011
          • 739
          • united kingdom
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            and the IC just test in circuit pins 7 and 8 together 200ohm scale power unplugged
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              #26
              your diodes you can test in circuit,if you find one with an odd reading take it out and retest
                I tried force power it by jumpering
                pin 1 ON CNR4 connector its ON/OFF with GND with mainboard and inverter disconnected.
                i can hear it's trying to start but i can hear some clicks as i have a short on something...
                i checked all of the small diodes, all seemed ok.
                the next thing is to check the transistors which is a pian,
                i hate to wick them out....
                any more ideas?
                So you ground the on/off pin instead of using force on resistor (100~1K Ohms) between 5VSTBY and the ON/OFF pin?
                I do not know if the ON/OFF pin signal is active high or active low.
                • selldoor
                  Slow Learner
                  • 7870
                  #28
                  The datasheet for the PWM controller IC is here
                  After checking the resistance pins 7-8 with power off, when it is powered on check the voltage on pins 7 -vcc and 8 gnd Very very carefully as HIGH voltaqe area although
                  test should show less than 20 vdc
                  "VCC (Power supply)
                  This pin is the positiv supply of the IC. The operating
                  range is between 8.5V and 21V.
                  To provide overvoltage protection the driver gets
                  disabled when the voltage becomes higher than 16.5V
                  during Start Up Phase."
                  • s_henya
                    • Jan 2011
                    • 483
                    • Israel
                    #29
                    So sorry for the delay in update...
                    (i waited for my new meter to arrive Fluke 17B+) my old one had been giving me trouble..
                    so for the resistance test on the 2A180Z ic: between pin 7 and 8 i got 30k ohm
                    for the voltage test : between pin 7 and 8 i got 13.23vdc
                    is there anything else i should test?
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #30
                      Replace the start up caps , I repaired on of these with the same issue the caps next to the transformer were the issue.
                      • s_henya
                        • Jan 2011
                        • 483
                        • Israel
                        #31
                        i already replaced all of the elc' caps, do you mean them?
                        or the blue ones?
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #32
                          or the blue ones?
                          I mean all the smaller caps and all the caps next to the transformer.
                          • s_henya
                            • Jan 2011
                            • 483
                            • Israel
                            #33
                            I used budm tip on force starting the psu,
                            (with logic board disconnected: jumpered a 265ohm resistor from 5v pin to on/off pin)
                            now i have power but not the correct voltages..
                            CN6:
                            PIN 1,3 should be 18v but only got 12.22vdc
                            CN5:
                            PIN 2 should be 12v but only got 5.18vdc
                            CN4:
                            PIN3 GOT 5.14 sould be 5v OK
                            PIN 6,7 (not connected) shoud be 12 got 5.18vdc
                            didn't check the voltages that goes to the invertor...
                            any more tips?
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #34
                              CN6:
                              CN5:
                              CN4:
                              any more tips?
                              Have you checked that the pfc is running ?
                              • s_henya
                                • Jan 2011
                                • 483
                                • Israel
                                #35
                                no, sorry :-(
                                how do i check the pfc?
                                • lepak06
                                  TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                  by lepak06
                                  Hello
                                  I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                  The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                  Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                  All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                  But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                  01-12-2023, 01:43 AM
                                • toty79
                                  Hisense LTDN50K220WSEU stuck in standby
                                  by toty79
                                  Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                  As per Hisense tv title LTDN50K220WSEU stuck in standby
                                  PSU rsag.820.5687 HLL 4855WF
                                  Main rsag 7.820.5842
                                  I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                  05-01-2022, 04:39 PM
                                • lego1234567
                                  LG 32LB1R - stuck in standby mode
                                  by lego1234567
                                  Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                  What could be the problem ? Thanks...
                                  01-21-2024, 03:39 AM
                                • Stunt
                                  Hp Laptop Stuck on Hp protected by hp sure start screen
                                  by Stunt
                                  Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                  I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                  I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                  Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                  screen that's it and stuck there. I left it until the following day and i still...
                                  09-02-2025, 01:51 PM
                                • Rusenga
                                  Samsung UA39EH5003R Stuck on standby
                                  by Rusenga
                                  Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                  Connector CNM803:
                                  TV ON
                                  Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                  TV OFF
                                  Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                  09-18-2021, 11:51 AM
