Sony Trinitron KD-28DL10U red, green, red, green OCP fault
  • PCS_
    • Mar 2015
    • 25
    • England
    Re: Sony Trinitron KD-28DL10U red, green, red, green OCP fault
    It appears d705 is shorted! All the rest show ok
    I repair a lot of retro consoles like mega drive, SNES, n64 etc and I'm also now trying to get into repairing Sinclair's
    • PCS_
      • Mar 2015
      • 25
      • England
      Oh and I love gaming especially on the retro's
        • 30979
        sinclair's are a bastard, the output isnt true pal.
        some monitors will work, others will give a dark or unsync'd picture.
        i'm experimenting with one to get a decent composite output.
        the best test monitor is the philips cm8833-mk2 originally sold for use with amiga's
        i use one on consoles, arcade games etc.
        it's only 14" though.
          • 30979
          i just noticed it has a 5r parallel resistor - i hope you lifted one end and re-tested!
          • PCS_
            • Mar 2015
            • 25
            • England
            Ok that was definitely a schoolboy error on my part. That diode is fine!
            I'll have to see about getting hold of a Philips for test purposes. Would sit nicely on my bench. Just like a big tv for gaming on. I'm the same with modern consoles.
              • 30979
              i'll tell you what - i bet this would interest you!
              http://www.sintron-hk.com/GBS-8220-a...-P2699965.aspx
              • PCS_
                • Mar 2015
                • 25
                • England
                #27
                I have been thinking about getting a converter like that, great little things
                I've just lifted L704. How would I test the driver chip? I'm used to testing components on a smaller scale, ie 5v circuits lol
                  • 30979
                  just power the tv up and see if it still flashes an error - dont expect a picture!
                  • PCS_
                    • Mar 2015
                    • 25
                    • England
                    #29
                    Still doing the same. Can hear high pitched noise and the thump when tube tries to come on
                      • 30979
                      right, start looking at the psu section for something shorted on the outputs
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        #31
                        Frame-timebase issue.....?
                        TELEFIX
                        • PCS_
                          • Mar 2015
                          • 25
                          • England
                          #32
                          Hi Alastair. How would I check that?
                          I'm trying to work out the best way to discharge the big power caps so I can meter up components. Want to check the HOT to see where things stand there too
                          • R_J
                            • Jun 2012
                            • 9535
                            Did you check the +200 volts on the crt board? If its there that eliminates a lot.
                            You should have +135 volts on the collector of the h.o.t. If it is there, check for posible shorted diodes around the flyback transformer. D536 & D539 gave problems on similar chassis.
                            if the high voltage does come up for a sec. then I would think the power supply and horz. output are o.k.
                            There are +15 and -15 volts that come from the flyback and supply the vertical o/p ic see if they are there (the test points are marked on the board)
                            Just a few things to try
                            • PCS_
                              • Mar 2015
                              • 25
                              • England
                              #34
                              Thanks for that, very helpful indeed. Its all a learning curve for me. I'm attempting to eliminate all the tests that can be done with the set in a discharged state. I'm not used to working with HV caps that are full of charge yet. I'm fine with discharging the anode.
                              Any tips or tricks of the trade would be appreciated because I doubt you wait for everything to self discharge before testing resistance. im quite safety conscious.
                                • 30979
                                get a few high voltage resistors, 470k or higher and solder them in series - put wires on each end and stick it in a plastic tube like a bic pen body.
                                you can discharge anything other than the tube wih that.
                                the reason you solder several inline is to prevent an arc between the ends.
                                • PCS_
                                  • Mar 2015
                                  • 25
                                  • England
                                  #36
                                  That's a great idea, but what about insulating the wires to the cap or is that not necessary? Also what sort of gauge wire are we talking?
                                  I've got a pack of assorted resistors 1/4 watt carbon film type as that's what I use but I don't think they will handle high voltage will they?
                                    • 30979
                                    cap???
                                    high voltage resistors are usually gray, not the usual light-brown carbon or light-blue metal film.
                                    wire guage is not important because the discharge current is very low - insulation is important - it must handle what your using it for.
                                    so 500v is a good number.
                                    if you look at good psu's they often have a high voltage resistor across the mains cap to discharge it.
                                    maybe you can salvage a few from some scrap boards.
                                    the other thing, you can check caps with your volt meter before and after you discharge them - you may be surprised just how many dont stay charged anyway.
                                    they discharge through the load.
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      what he means by retro computers are like some of the older Apple Macintosh PCs used Trinitron CRT's and also some Atari amigas I believed use the same as well as Trinitrons of the old school era built ega style for some of the old IBM PCs with the EGA cards
                                      • PCS_
                                        • Mar 2015
                                        • 25
                                        • England
                                        #39
                                        cap???
                                        By cap end I meant not using just wires but possibly meter probes?
                                        500v I don't think I've got anything rated for that!
                                        I wasn't sure about testing big caps with a standard multimeter either as My father had a special high voltage meter that he used regularly for tv work. I do have several PS3 psu' from fattys so maybe there's sometjing in those that I can use, never really had them to bits as I just swap them out if they become faulty
                                          • 30979
                                          most meters can do 600v dc
                                          i cant see you going close to that as long as your not trying to check the voltages on the crt.
                                          • sickboy
                                            Strange CRT Fault (Sony Trinitron M1410U)
                                            by sickboy
                                            This is a CRT I sold a few months ago and it's came back with this weird issue. It's intermittent, but not a thermal fault, or tap sensitive - just completely random. The right side of the picture completely blanks out (picture is not shifted). The on screen display is unaffected though, so not a fault in the line section. Anyone seen anything like before in a CRT?
                                            11-10-2024, 05:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • cmonkey
                                            Sony Trinitron KV32FV27 Suddenly Dimmed
                                            by cmonkey
                                            A couple of days ago I finally got my hands on a locally sourced Trinitron and after lugging all 175 LBS home I gave it a good cleaning inside and out. The guy said it had been in a shed for 2 years, but the outside wasn't too bad. The inside was another story and while there was no evidence of mouse, it had certainly been kept in a VERY dirty home.
                                            I cleaned it to an acceptable level of grime, at least clean enough to where nothing would heat up from the dust insulation. I then tried it out and it worked!
                                            I'd say I had it on for about 15 minutes or so and then lugged...
                                            04-28-2023, 06:25 PM
                                          • motorahead
                                            Sony Trinitron (KV-20FV12) Vertical Deflection Stopped
                                            by motorahead
                                            Hi everyone, I've been troubleshooting my 20" Sony Trinitron (KV-20FV12) CRT after it failed to show a picture. The standby LED is blinking 4 times, which according to the service manual is a failed vertical deflection via the self-diagnostic check during power up.
                                            After getting the TV checked out by a technician and doing research on my own. The most obvious first step was to replace the IC502. I've done so with an exact NOS replacement with no luck. I've read a few suggestions to make sure the 12V supply to pin 2, but that voltage check would seem misleading? It seems if the...
                                            10-21-2023, 03:50 PM
                                          • jimjoe123
                                            LCD TV Green/Pink screen problem
                                            by jimjoe123
                                            I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                            Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                            Then each time...
                                            02-23-2020, 01:29 AM
